Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 28
Yes, way too close.This sounds more like the gear spacing is a little too close.
No real plan here. 5th (which is the first OD in my trans) works fine. The way I am geared (3.55's) I'm good for 221mph at 7,000rpm. I've only gone 208 so far though.
If I wanted to go faster I would put a taller tire on or swap out to 3.08's.
He hasn't gotten to that experiment yet. Be prepared for his full findings when he does, they're sure to be idiotic.I would expect because 6th is an overdrive gear. Meant for MPG on the highway, not performance driving. I'm sure you've noted the RPM spacing & how much larger 5th-6th is compared to the rest of the box.
Lower losses when the power is carried straight down the input shaft/mainshaft instead of across two sets of meshing gears when the countershaft has to be used (which is any time the gearbox ratio isn't 1.000).Why not go with a higher gear ratio and use 6th gear?
Ah. That makes more sense. That goes back to the 1.00 ratio making the most power on the dyno as well.Lower losses when the power is carried straight down the input shaft/mainshaft instead of across two sets of meshing gears when the countershaft has to be used (which is any time the gearbox ratio isn't 1.000).
Kind of makes you wonder why top gear isn't 1.00, though doing so probably forces other compromises like getting a low enough 1st ratio without making the case physically bulkier. Actually, 1.000 top gear 5-speed boxes have been produced. I think the 928 Porsche box was set up this way.
Norm
That 5.30 would be the product of two gear reductions, one from the input shaft to the countershaft and one more from the countershaft to the mainshaft. 2.00 and 2.65 would be one possible combination, though I doubt any transmission designer would ever choose exactly 2.00 anywhere.and without using more then 2 shafts to make a gear (some transmissions use more then 2) the deepest gear you can put in the trans will always be limited by the largest gear(and the smallest) you can get in there. i.e. 5.30 1st might set you up for a great 6th or 7th gear, but now you need to fit (I am pulling numbers out of my ass) a 20 tooth and a 106 tooth gear. oh yeah, and that 20 tooth gear has to hold 600hp+ in a 400hp car because 50% of the people who own the car with that trans will never leave well enough alone.
I'm not attempting to argue this with you. Just inject a perspective that most people don't have an option of experiencing.
I have spent a lot of time on a lot of different tracks playing with gearing in a quest for faster lap times. Most of the time by playing with final drive ratio's, but from time to time I have had the ability to play with the transmission ratio's at the track. I always had the ability to swap ratio's at home base, but testing at the track same day, same conditions is preferable. Based on that experience I can confidently say that it can be a lot better than a MT-82.
It's not one dimensional either. A person learns how to drive/ride around what they are given to use. They develop techniques/patterns to cope. When the gearing options open up/change different techniques/patterns can be used sometimes to great effect. Changing the gearing up and driving/riding exactly the same will not net the gains one will see form changing the gearing up and then taking advantage of what it has to offer.
I've driven in anger S197's with 3650's, T-56's (pretty much a 6060) and MT-82's. I also have a ton of gearing development under my belt. I don't like the MT-82. As far as I know you have only ever driven that car with a MT-82 in it. And I think it is safe to say you haven't done gearing development in the past. If I'm incorrect I apologies. That said, maybe I have some insight and can draw some conclusions that you can't?
Because faster.I don't have any complaints so why bother?
Wait, did you change your username or become a sponsor?! I'm on my phone so I can't tell.Because faster.
I've had combo's that would run very respectable race winning times. But I went looking for for more. And from time to time that paid off in easier wins and in a few cases lap records (The lap record, not some class lap record).
Are you the fastest guy in your class?
Both.Wait, did you change your username or become a sponsor?! I'm on my phone so I can't tell.
Very niiiice!!Both.
I'm pretty damn sure it's a TR-3160.
Take a look at the picture of the bottom of the transmission case from the teaser videos (#3, 15-17 seconds):
http://www.mustang6g.com/forums/showthread.php/svt-gt350-mustang-5525.html
Now, look at this picture from the underbody of an ATS with TR-3160:
http://www.iveho.com/wp-content/uploads/2012/07/P10100074.jpg
Finally, compare to a TR-6060:
http://www.supraspeed.com/images/tr60601.jpg
It is a modified 3160. When the Ford rep, Jamal Hameedi, was asked the question directly, that is what he had said:
http://www.mustang6g.com/forums/showthread.php/new-shelby-gt350-6265.html?p=162964#post162964
