I hate this damn car.
lito
Caracas, Venezuela
Today I decided to use it to pick up my daughter from a friend's house.
Started nice, let it warm for a couple of mins and when I went to move it... pam pam pam PLUM PLUM PLUM!!!! heavily in the engine.
Shutted it down quick, took the DD and grabbed a toolbox on my way back.
Here is what I've found:
Debris in the valve cover:
Other side looks good still:
I am so sick of this car giving me troubles, these phasers were torqued to Paschal's spec with loctite.
Plan is:
- scope inside for damage and clean as possible, if everything looks ok?
- Ford phasers with lockouts.
- try to align the broken phaser at zero to mark a link for the swap.
- run it and change oil and filter
- may have to take the k-member out soon for mods and remove the pan and clean some more.
Will try to go ahead with this without having to remove the whole thing out, won't even take the front cover off, I am so tired of this damn car that if I would need to take the engine out I may take one stock longblock I have at the shop, demod it and off it goes.
Only hoping that the PTV contact was not as hard that damaged a valve(s), these heads have only 200miles on them, this is the third set, first ones (livernois stage2)melted from a lubrication issue, took the motor with them, second set (livernois stage3) came with defective guides from them, these ones are FRPP CNC base ones with stock valves.
That sucks Lito. What would cause that to happen?
dysan
Dis-Member
Williamstown, N.J.
Well crap!!! I guess that seals my decision when I do cams to not use degreeable cam gears and only do the trick flow crank gear.
Sorry to see more troubles and I hope it's not too bad.
fdjizm
Drag Queen
NY/NJ
Ouch, those bolts didn't hold that cam sprocket in place, when did you get that put in?
Don't be so hard on the car, it's awesome, parts go wrong sometimes.
OUch! So did the plate actualy come loose and start knocking back and forth? Looks like the bolt heads dug grooves in the plate.
lito
Caracas, Venezuela
I really think it is a design thing, 4 retaining bolts are too small for the tension the have to keep.
Some times I think that the car is telling me something, I am not superstitious at all but c'mon! is like it does not want me to drive it or else, I have 2.5 years of only pouring money into it and or either the parts I receive are crap or it breaks in the most mysterious ways. Everything that could go bad, happens in this f*****g car!
BruceH
BBB Big Bore Boss 322
When I was thinking of degreeing my cams you were the one who told me to use the trick flow crank setup. What possesed you to go with the adjustable cam gear?
I hope nothing else was damaged. Do you still have your original phasers?
TurboX
Formally Buzz Lightyear
San Anto,Tejas
I can only hope the BBR adjusters are better. Tommy@JPC warned me of this exact thing, based on his recommendation is why I got the BBRs.
fdjizm
Drag Queen
NY/NJ
I would have put those things back on the shelf for just that thought, go with your gut! :mad2:
lito
Caracas, Venezuela
I studied all the options first, including the TFS's, and ordered these, once I got them degreed and thought that the TFS option was still the best (and cheaper too btw) so if I was to do it again, I would use TFS. Now I will just drop the phasers without degreeing.
My original phasers got all marked and slightly damaged when the first engine went so I discarded them. I already ordered new ones locally as they are cheaper than in the US.
Too late for that, what worries me is that I am not the only car with those down here.
06silverbullet
orange county, ca
i felt that way about my car last year...i don't anymore but i decided to keep the car to a basic bolt on toy w/ suspension. less likely to have issues on a basic setup and thats why i did it, plus it's my DD
05stroker
Never enough power guy!
Bullard Tx.
WOW!!! Sorry to see the troubles on your car again.
I am really sorry to see this. I was going to use a set of those gears when I do my 127550 cam swap after the car is tuned and off dynoed on the current cams with the Trick Flow crank gear. I guess I will plan on reusing the Trick Flow gear with the new cams.
8306gt
Conroe, Tx
Plan is:
This is exactly why Paschal Performance no longer manufactures or sells these gears. Clifford and I were discussing using them in my engine and he recommended to just lock the cams out and use crank gears and shims to degree. Sorry to see this happen. Did the valves and pistons hit and if so did you bend valves?
lito
Caracas, Venezuela
I think is the best bet, are you planning on degreeing it with the engine in the car?
Car is in the parking lot of my apartment building that is underground so is very complicated to get it towed s it sits, I will just drop the locked phasers there and move it to the shop, then do the tests there.
