TSB 11-8-4 6r80 transmissions - fluid leak from bell housing - built on or after 4/15/2011 through 6/8/2011
Hey, I just wanted to say thanks for posting these TSB's. I really appreciate that you take the time to make them available to all of us.
Is there a tsb out for a leaking differential? It's leaking from the side of mine where the axle goes out. This isn't normal is it?
Yea its fairly damp looking on the drivers side of the diff but it's def coming out where the axle tube is. Axle tube itself is pretty damp. I mean it wasn't dripping out or anything but there was probably enough to make a drop where the axle tube meets the diff.If its just damp on the axle tube, on the drivers(?) side by the vent, thats nothing to be concerned with. Especially if you drive spirited....
^^^^^^^ i cant read any of those???
Just curious. For the cold shifting problem. Would anyone remove an aftermarket shifter and bracket, replace with stock, before going in for the tsb on it?
My car has 2k miles on it and that cold shift tsb fluid change didn't do much if any for my car. IMO I'd use the time spent installing the stock shifter back in the car on switching the fluid yourself with a high quality synthetic gear lube. And you won't have to worry about the dealer putting a new scratch on your car.
I had the TSB done with the JHR bracket installed, no grief from my dealer. I've since installed the MGW shifter.
Did them performing the tsb help?
