Discuss this absurd bullshit (serious input sought, vendors?)
FalconGTHO
The Reporter
Scorpion Gulch
On another (small) forum I commented about how WHOLLY useless shorties are, leaving out in comparison to LTs. This is in response to the OP who laid out a plan for their V6 which includes a ProCharger and shorties. A member, not the OP, and I had this exchange in PM. I think hes out of his tree, just absurd.
I'm not posting my comments about headers and the motors in the S197's anymore ... especially with (name withheld) and all his mechanic drama. (name withheld is NOT the OP, btw)
Here's my take and my challenge to anyone ...
The exhaust on these motors is absolutely outstanding for the displacement. There are no gains from headers, even LT's that don't include "tweaking" AFR, boost or timing ... OBTW you can achieve power gains by tweaking those w/o headers.
Outside of looking/sounding cool ... Headers = CEL's, failed emissions, leaks = PITA
Bigger cubes, poor designs, absolutely ... headers can/do work.
Here's my challenge: When I install the KB after getting back stateside, I will post on any forum the following:
I'm willing to pay for the dyno, datalogging and required adjustments on a boosted 4.6L to test the effects of LT's. Boost/pulley size, AFR, timing will NOT BE changed from the baseline ... and will be documented thru datalogging. This will isolate only the effect of the headers on the performance of the motor. All I ask is for a loner LT setup ... I'll even install them or pay for it.
How many takers do you think I would get ... ???
My response:
"Lol @ "mechanic drama". I dont know what his "credentials" are but I earned my 2 year Auto Tech Degree as well as my ASE Master REcertification and while both of those are many years old Ill go wrench to wrench with ANYone on the board. There could possibly be one(s) that have "done more" as far as the variety of cars theyve worked on or the amount of hands on, tech heavy mods theyve done but Im not worried that theres anyone on here that knows more than me. If there is, great. Its not going to be by a wide margin, thats for sure. Thats not horn blowing, thats just truth. And unless and until someone can conclusively prove to me that Im full of shizz Ill contuinue to feel that way and state such.
That being said, its silly to say on a boosted application that youre NOT going have an increase with LTs over stock, cast iron, log manifolds. If youre saying, "Well its because you have to tune for it", well duh, you have to tune for any direct engine mod on the S197 4.6 unless its one of those 3 cold air kits that are "tuneless (two of which are by the same vendor and just rebadged for the other) and thus otherwise suck.
Theres no way you could run a boosted 4.6 that is tuned well with log manifolds and then run it with LTs WITHOUT a retune and STILL be safe. If you dont evacuate spent gases well you have less available "clean" cylinder volume or conversely if you expel spent gases BETTER youll have more available cylinder volume with which to make power. Additionally, the charge air wont be "contaminated" with leftover gases, or less so for sure, so it works twofold. But, given all that, you HAVE to adjust for it. Thus your "challenge" is unfair because youre demanding that the LTs perform at their best WITHOUT a tune yet the stock manifolds have received a specific tune. Also, the test wouldnt be able to be an exact, direct comparison anyway because of the climatic changes between test days or even just the time it takes to test, then R&R the manifolds and test again.
As far as getting any takers, no you wont, but not because anyone has a vested interest in selling LTs, but simply just because of the logistics of it. Who has a set of LTs laying around just waiting for a test on them and then would be willing to get back used LTs? To prove (or not) your point youd have to finance all this yourself and buy your own set.
Myself, Id NEVER pull a stunt like this and risk the almost INevitable engine damage from a tune NOT written for the LTs. You say AFR wont be changed from the log manifold baseline. Dont worry, it will change on its own to lean, its just a question if it would be "catastrophically" lean. Either way, without changes, its likely the engine would LOSE power. But WITH a proper tune, GUARANTEED the power would be greater than the log manis. The only question for someone is if the gains justitfy the price but THAT question pivots the decision for ANY tech heavy engine mod.
My point is that no MATTER the engine, shorties are a bunch of BS. They DONT provide power in ANY form, they merely "dress up" the engine bay and shave some weight. Ive read/learned from too many people over too many years who DO know more than me to disregard LTs in a boosted application.
As far as the rest of your objections, headers do NOT automatically result in CELs and failed emissions. They will if you dont get a tune AND youre using a catless mid pipe. Without cats and rear O2 sensors, yes, youll throw a code and a CEL. If you tune, you can have the rear O2s turned off. But yes, youll still fail emissions UNLESS your particular location allows for one "Not Ready" parameter. Emissions failure varies from state to state based on how strict or not they are. If theres a visual, then yes, youll fail without cats but again it also depends on how thorough and conscientious the testing station personnel are REGARDLESS of how strict the state standards are or not. Use a catted mid pipe and O2 extenders and youre good to go. You MAY have to use the "spark plug non fouler" mod hack but so what, mission accomplished. Its all up to w/e a person wants to do and the level of effort theyre willing to put forth to acheive the goal. As far as leaks, again, not a universal guarantee. Using high grade gaskets and fasteners will avoid this almost every time. But it IS a mod, a modded car, so if a person wants "no hassle" stock reliabiity they need to STAY stock.
Myself, Im a FIRM believer in not leaving ANYthing on the table, thus when "advice" is sought I speak just like *I* would do. If that doesnt fit a persons goals, wallet or level of effort theyre willing to expend, so be it. Their ride, their choice. But I dont believe in "aiming low" for convenience. Thats why I havent turned a wrench on my car. I dont do shizz half azzed or part way, its all or nothing AND ALL at once, not this "piecemeal" over time crap. I may never get shizz done on my car but when I do it will be ALL done at once exactly how I want it with no compromises or shizz left behind.
My question for you is are you going to have a built block when you go boosted? If not I would ask why even bother with a KB? No matter whose brand of boost or the TYPE of boost, the stock 4.6 is only reliable (consistently but ANYthing CAN happen) to 470ish at the tire. So anyone who boosts a stock block is limited to that no matter where or how the boost comes from.
His response, which to me is so dumb I just stated we wouldnt discuss it further in my final response:
All else being equal, the only way to make more HP is thru AFR and Timing (and RPM potentially). It's cheating to adjust those to a different level and then give credit to the component. Just like CAI's ... the HP is in the tune, not the stupid inlet. Companies won't sell a tune without a CAI ... except for FR, but even they want to get in on some if and offer a filter change as part of the package.
Another way to test is thru flow testing ... if a determined CFM produces XX HP, then it doesn't if the stock manifolds flow it or headers do ... they will both produce the identical HP at the same CFM. I've never seen anyone publish those results either ... SEMA would probably ban whomever did :).
I suspect noone would sign up for the challenge ... but consider this, why haven't the header companies ran "Tech Articles" on their products in the magazines? Isn't it more than coincidence that headers are a part of an overall project ... and when they are installed in isolation, the article never discusses the previous Timing, AFR or RPM levels prior and after the test?
It's more than a coincidence ...
Scavaging is not that big a deal on these small displacement, low rpm motors ... I know the science behind it ... people get too amped up over that.
As far as the KB ... I want this to be a one and done scenario. The KB will never let me down when its time to upgrade the HP ... or at least not to a level I want to achieve.
The internals will be stock initially ... then as I get the rest of the car ready for more HP ... eventually forged internals will follow. Keeping it under 600WHP is the mandate ... KB says I can get to 575WHP with little effort. I like their design ... the look and the price.
My final repsonse:
Well I guess well just have to let this discussion be then. I couldnt disagree with your entire premise any greater than I do already.
Just one question. Youre going to do your build, through all its permutations, on stock, cast iron, log manifolds, yes?
As far as KB, yes, IF a person is going to get an s/c they are the ONLY way to go IF they fully intend to get the MOST out of it by pairing it with a built block. Otherwise, like I say, it doesnt matter who, where or how the boost comes from, youre limited to 470 wheel.
Bottom line, this guys saying w/e power increase comes from LTs is a result of the tune and thus you could get the same results just "tuning more", I guess. Just fucking dumb.
05mustang_TT_charged
Because Race Car!!
LSU Country
Pretty simple actually.
1. An internal combustion engine is just an air pump.
2. When you increase the efficiency of the air pump it makes more hp.
3. Longtubes flow better than a cast iron log manifold.
4. More air out = more air in which = more horsepower.
Pretty simple...You can not debate physics...if the log manifolds flow enough air to fully sweep the cylinder of exhaust gas then there would be no gain with a longtube...But that isn't the case with 99% of the exhaust manifolds built today...
OhhFiveGt
Long Island
A lot to read but this guy is honestly just slow. I run LT headers with a catless mid pipe on my car and guess what... No check engine light passed NY state inspection and saw a HUGE increase in power compared to stock manifolds with a catless pipe. LT's provide MUCH better air flow which in turn allows you produce more power then the restrictive stock hunk of iron. As you stated yes you need to tune regardless of what you do to your car but the more that you do usually the more power you will see. If what he says was the case there would be zero need for mods and tunes would be the only thing anyone would be doing to their cars.
FalconGTHO
The Reporter
Scorpion Gulch
/\ Exactly.
Exactly, which was my point to him. But hes saying it comes from the tune. Well, yes, in a sense, but thats simply because you HAVE to tune for the change in cylinder conditions.
firefighterhill
Riyadh, Saudi Arabia
Sounds like someone is not as smart as then think they are. Bigger intake, bigger exhaust mean more air which means more fuel is needed. If power was all in the tune you wouldnt need things like boost-a-pumps, larger MAF sensors.
I think where he gets his misinformation is that on the s197 almost all engine mods that dont require a retune, dont really add any power. This is because the computer is VERY sensitive to changes in the amount of air flowing in and exhaust flowing out.
Im sure someone else can chime in and let us know how much variation the s197 will take before it throws a CEL.
If you were to retune and ONLY change the A/F, to bring it up to a safe level and touched no other perimeters the LT's would make more power.
He needs to relearn the basics on how a internal combustion engine works. And then worry about the physic's behind long tune headers, equal length headers, header collectors, 4 into 1, 4 into 2 into 1, etc and the advantages they all have in producing power and why they perform the way they do.
And his comment on CAI's not making power is ignorant. Colder dense air means more oxygen which means you can add more fuel while keeping a safe AFR, which equals bigger boom, also means the spark plug can spark closer to TDC, which means your engine is more efficiently using the energy derived from combustion.
How the hell does he think a super charger works, and why does he think super chargers benefit from cold air intakes and inter-take coolers? I bet hed be floored if you told him by adding LT's to a super charged car it can lower the amount of boost it makes with any given pulley vs a short header. WHILE MAKING MORE POWER NO LESS.
Atlanta GA
Props. I don't care that much anymore about forums/mustangs enough to argue in lengths of paragraphs. If I cannot "e-own" someone in about two sentences I just let it go... Hell, I think I post too much as it is when I put about 4-5 sentences... I can only imagine VTXFrank on his little Ipad going at it. :thud:
sinabite
Was actually debating installing headers on mine adter a procharger.......you answered my question....no headers. Thanks!
twisted_GT500
Columbus, GA
Actually MM&FF mag, as well as 5.0 have done a retardly high number of articles where they've tested different headers. And in the majority of them I read they included the changes they made to the tune. But the fact that he thinks you can bolt up different headers without changing the tune lets you know his knowledge base already. It's been time tested that LT = power!
Fullboogie
King of the Ski - OG Jr.
Houston
I think your statement "no MATTER the engine, shorties are a bunch of BS. They DONT provide power in ANY form, they merely "dress up" the engine bay" is incorrect. I've seen enough tech articles to know that while shorties do not provide the same peak hp gains as LT's, they do provide very noticeable low and midrange gains over stock manifolds.
I personally would not spend my money on them, and would rather go LT's. But I wouldn't make that blanket statement about "absolutely no gains" if I were you.
SilentScope
Chemist by profession
South Florida
who cares about another dude from another forum who's friends with a dude from a forum who once met a guy owned a v6 with longtubes?
BORINGGGGG... MOVE ON
Powered by Ford
Good points and basic summary. The increased flow is due to much more than explained pipe diameter, collector design, equal length pipes, exhaust scavenging, reduction of backpressure, etc. You can even try to further explain it with the valve overlap with the camshaft and how the exhaust "pulses", but at that point it is over most people's heads.
And with exhaust or other bolt on's you are typically "freeing-up" power and torque due to the lesser restriction. Cause this guy could say "headers don't make any power" and he would be kind of true, but that would still a convoluted argument (splitting hairs).
FalconGTHO.
At the end of the day you just have to let it go, everyone on the internet claims to be an expert at everything (hell, I know I sure am not). I really only participate on this forum because I find that most of the tech information is accurate and helpful. Let that guy believe he can defy physics - I know plenty of others that think they can too.
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
I've heard this come up before, there was a long thread on modularfords.com.
I started a thread asking for dyno results after changing headers on a FI system.
http://www.s197forum.com/forum/showthread.php?t=39766
Results here from one test. Solid gains with every brand of header. Perhaps there is a difference depending on type of supercharger
http://andersonfordmotorsport.com/dmdocuments/media/3ValveHeader.htm
I'm not sure if failing to re-tune after a swap would be dangerous, re: AFR. If there is better exhaust flow out of the cylinder you should see an increase in VE. That extra air now filling the cylinders is going past the MAF and fueling will be adjusted accordingly. Am I forgetting something here?
Re-tuning would be likely be necessary for optimization, though.
Guess nobody seen Engine Masters' header length test.
There is way more advertising jargon in here than actual data.
I had VMP retune my 2010 GT with the Roush M90 blower and tuned for 94 octane ( and no ethanol in it). Other mods at the time were the FRPP twin 62mm TB and the K+N panel filter...and FRPP FRS-500 mufflers. Car ran good.
Fast forward, and in went the JBA LT's with the mating hi-flow catted H section. These are the titanium ceramic coated LT's..... with 1 5/8" primaries and 2.5" collector....and 2.5" for everything else down stream. Car again retuned by Justin at VMP....and again tuned for Chevron 94 (and no ethanol).
Any idiot could easily tell the difference, it was blatantly obvious. This is on my 2010 GT with 5r55s automatic.
Before LT's ( measured on local dyno). 350 rwhp / 320 rwtq
After LT's ( measured on same local dyno) 386.3 rwhp / 376 rwtq
That's an increase of 36.3 rwhp. And an increase of 56 rwtq. The JBA LT's are a lot longer vs kooks etc, so the increase in TQ is shifted further down the rpm scale...which is where I wanted it. 5 psi boost before and after the LT install. The LT's provided for a LOT more TQ, from Idle to redline.
I also looked at FRPP shorties, and IMO, for the expense + labour, the gains were minimal.
