zaino was decent years ago. Its old hat and lumped into bandwagon products now.x2 I won't use anything else.
Problem with zaino cars is they push z5 so much, you look at them at shows. All spider scratched.
Just plenty better out there for cheaper which does not require a system.
Don't do it in that order!
Wash it first, then clay it, then wash it again to get rid of any clay lube residue. Then wax it.
If you clay it first, you're essentially going to be rubbing any dirt that's on the paint around, causing more swirls. Even in a garage kept car, dust can settle onto paint.
Ideally, a car should be completely dust- and dirt-free before you ever actually touch it. It's always easier to prevent swirling than to polish it out.
Lava i went to CG site but does not explain it. can someone tell me whats so great about this? does it have fillers? and i us BFWD can i top it or is it a stand alone product? thanks
I was told by CG to apply jet seal 109 then black light and then lava. Any pros or cons about that method.
Another question for the detailing gurus on different waxes. According to CG their 5050 wax is great for dark color cars and LAVA is great for all colors. I have a vista blue car which wax would you guys recommend and I would like to sway under $100 and I will be using it with black light.
