Are the fans kicking on like they should? Did you try taking the temp sensor for the fans out and putting it right behind the fan?
Sometimes fixing it without an explaination is just fine. Sure hope that is what does it for you. I hated to hear you were going to shove it in the corner without getting it all done.
From my understanding Im thinking so.sitting in the driveway with ac on at 202 is normal is it not?
HAHA But your drivingYeah, the more you mod the more you will always be tweeking. I still havent gotten a decent idle/driving log for lito to fix a couple small issues and it has been probably two months since we did any revisions.
I think Jeremy is going to be unavailable for awhile yet. Your best bet would be to swap over your sending unit if you can I think.
Josh
I should have known better lol
Havent had a lot of time to drive the car
But it got hot here outside 95 degrees
My wife had me put new brakes on her cousins car, So I took the mustang when we dropped her cousins car back off
this was the first time I ran the car with the AC on. good drive like 10 miles.
The car was at 230 when I got to her house
I sat ion the drive way fro a few minutes while my wife took her the keys
Car didint cool down below the 230.
needless to say I was pissed as hell
So I told my wife that we would take the interstate back home
Well on the highway the car cooled down to 210.
So when I got home I let iot idle in the drive for a while.
It stayed at 210
I never put the rad cover on , as I have a new glass one we need to paint
Also the front bumper needed to come back off so I never installed the under carriage plastic, my son wonders if it isnt turbulent air flow causing the issue.
I double checked the fans AND THE ARE RUNNING FINE
So I ordered this today UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit
Im thinking its a air pocket
Those fan are junk. When I had them going the correct direction. I had temps at 230. Now that I put the stocker back in My temp never go above 200 degree. I don't see how you have an air pocket. I would just bite the bullet and put the stocker back in or buy some replacement 13' fans.
