Mike K
WANNA BE FAST
Hell yeah! Now I can attempt this install.
I guess I'm kinda like you in that I can do pretty much anything with a wrench, but wiring up a relay is like rocket science. I installed my WOT box tonight and its actually not that hard. One tip that I haven't seen posted in other DYI write-ups.........after you disconnect the 3 large PCM connecters (the ones that latch on) follow the harness back to where it attached along the upper fender and detach it from its plastic snaps. Then you can pull the harness almost all the way up out of the engine bay which makes soldering those little pesky wires way easier. Also, when they say to poke a hole in the rubber boot thing to run the wires, I would just cut a slit, when I poked a hole with a screwdriver I was under the dash using every explanative in the book trying to fish those stupid wires through. Finally just snipped a medium sized hole and ran em through. Still sealed up just fine. Do yourself a favor and go buy a variety pack of shrink tubing. The supplied shrink tubing is too big. good luck.
A couple questions if anyone can answer, just got mine in today.
In the software, under launch control, what is alternate rpm and lockout rpm for?
Under no lift shift, should it be auto or what time/tps threshold is good?
I installed my wotbox and then I was all like...
racecar
Installed mine a couple weeks ago and I'm now sad that I have to wait until spring for the track to open. It builds over 4lbs of boost with the limiter set at 4000 and the 2-3 powershift is usually followed by a momentary loss of control with my inadequate stock tires on the street.
