AutoXRacer
The posts in this thread make me feel like whom ever you spoke to at ID is full of shit and just trying to sale parts. I was waiting to hear your results before sending my 2000s to them for " cleaning /ass fucking". I have some research to do now before sending them a thing. 2% does not kill a cylinder IMO.
No, no, no... The fuel inectors did not kill the spark plug, nor is the cylinder killed; piston top just has a few battle scares.
Injectors tested fine, no issues with them. They were just slightly out of tolerance. Post clean results did not improve or I should say tighten up the variance. So it was recommended to replace the three lower flowing injectors. The 4th was replaced at me request as that's the one that was glazing the #1 piston top as it flowed more than the rest. I want my 8 injectors to be as tight as possible.
So the injectors were not at fault for damaging the spark plug. I sent them to get tested to verify they were good and eliminate that variable.
The injectors tested good, just slightly out of ID's specs.
I fault myself for the #7 spark plug damage due to opening up the gap after they were heat cycled and used to break in the motor. I should have never touched the gap and just reinstalled them.
