SlowJim
Sparco Chrono would be a good fit for you. Standard size is 20" for hip width (Z on photo below) and wider size is 21". No seat is gonna come close to having the harness holes level with your shoulders @ 28" though.
Also, cue up the comments about those not being "real" racing seats in 3 ... 2 .... 1 ...
So I straightened up the seat back on my Recaros a little, and I do think that helps to hold me in place a little better.
There are two insurmountable problems, however:
- The forward angle of the top of the seat pushes my head forward some when I'm wearing a helmet. When I'm sitting in the seat, the top of my head extends past the top of the seat by about 3 inches or so. This puts the largest part of my head right at the top of the seat back, which is also its forward-most point.
- Even with my headliner modification (removal of the stock headliner, replacement with a glass roof headliner with the edges cut back even further, and lining the roof with a thin layer of padding), my head hits the ceiling with the seat inclined far enough forward to truly hold me in place properly. I fit fine without the helmet, but that does me no good on the track.
The first point almost forces me to lean a little forward when wearing a helmet. I don't do so much, but it is a little, and there's nothing I can do about it. It's one of the reasons I slightly recline the seat back more than perhaps I "should". The issue of headroom clearance just adds some finality to the amount of recline I'm using.
The bottom line is that my bet is that there isn't a truly good seat (good for high performance driving, at least) made for these cars, or for any other for that matter, that will truly fit me properly, and that this is simply as good as it's ever going to get.
Did I miss the post where you said you sat in an evo 3? Or are you just going off of the measurements on their site?
Seats....
The ultimate solution would honestly be a custom seat, and they aren't necessarily that bad price-wise, either. Joie Of Seating, Kirkey and Ultrashield all do custom-fabbed seats around the measurements you give them. Yes, they will be a bit more of a pain to install than the typical FIA seat, simply because you HAVE to use a back brace with them, but:
1) A custom-fit seat is NOWHERE NEAR as "uncomfortable" to sit in as you might think. It looks like (and is) an aluminum shell, with a thin pad of foam and fabric, but trust me, it's more cushy than you would expect. I have NO padding on my ass, AT ALL, flat as an ironing board from shoulder blades to ankles, and I can (and did) tolerate 3-4hr drives in one without real complaint, on Midwest roads (home of the pothole!). If the seat fits right, you're just snug in it, and very, very comfortable.
2) If you're worried about the "daily-driver" end of things, it honestly only takes 10 minutes (30 with an aluminum seat) to swap out for the stocker. Do the swap before you head to the track, and life is good. Get home and swap back, life is still good!
3) Pricing seems to be right in line with a standard decent FIA seat, and will weigh less than most of the ones not made from carbon-fiber and pixie dust. You know, the stupid expensive ones?
4) The aluminum seat requires more fabrication to mount, but isn't anywhere near impossible for a DIY guy. Bolt a seat adapter into the car, mock up the seat position with spacers (I use rolls of tape, since they're cheap and come in 1/4", 1/2", 1" and 2" thicknesses), then lay in a pair of side-mount brackets and mark with a Sharpie. You WILL need to lift the seat. When I did one in my S197, with the seat sitting on the car floor, I was eye-level with the center of the steering wheel, and I'm just under 6'. The thickness of the seat is only 1/8" without padding, which only adds another 1/4"! You WILL find your perfect seating position in one. Once the seat's in the perfect spot, just add the back-brace and harnesses, and you're off to the races.
5) I forget which it is (Kirkey, I think), but at least one of the manufacturers can do a bolt-on helmet containment section. Toss it in the trunk, and put it in place when you get to the track, and then unbolt it before you drive home. With it in place, it's a HUGE safety bonus on track, but kills your ability to swivel your head around on the street.
Of course, this pre-supposes that you have (or will have) a rollbar in place, to support the harnesses and the seat-back brace. Since you're worried about shoulder harness slot height, that is a potentially valid assumption.
+1
Kirkely Custom – Aluminum NO recertification
Carbon Fiber / Fiberglass limited life expectancy and must be re-certified. I think in 5 years from date of manufacture. I could be wrong but I’m sure someone can chime in.
