Forgot to update this thread last week. Ended up putting down 4 pallets of sod and it's looking good so far.
Today I installed a new TV antenna. Tired of the crappy signals from the indoor antennas. The bracket was designed for under the eave or mounted on top of the shingles. I wasn't going to screw through my new roof and I didn't have clearance mounting it under the eave. I bought a 5/4x6 pressure treated board and cut it to fit under the eave. Painted and screwed it into place so it reinforced the soffit nicely. Now I had something to mount the antenna base to. Except now the pipe wasn't tall enough to clear the roof. I bought a fence post and extended the pipe. Added a power booster and ran the wire into the attic.
Then I had to run power into the attic for the other end of the signal booster, so I ran a new power line down the crawl path with a couple extra outlets. Then I had to run a new cable line to my bedroom. With the new antenna, signal booster and amplified splitter I have much better reception on both TVs. Pulling in something like 74 channels (most are religious, shopping or Spanish).
I'm finally able to pull in the NBC station so I'll be able to watch the Tonight Show for the first time in 10 years. I heard Jay Leno retired?
