So is this essentially the same as paying for a stage 2/stage 3 porting job from a speed shop?
Stage 3 plus custom hand porting. He went way beyond my Foxlake porting.
Any thought on the change in combustion chamber size and what affect that will have on compression, just a thought.
Good work! They look great. Where did you learn to do that kind of work? I have done some very light two stroke porting work but I had a template and reference pictures....you are making me want to pick up a set of used heads to play with. Are you using any kind of template or guide?
Rm
Those heads!! Where do i send mine to and how much! And also going to text u today or tomorrow! if u dont hear from me by sunday text me!
Did you find out what was causing the problem with taping that hole? Just dirt, alum, factory defect.
I CCed my heads after the gutting/porting. Then I milled them till they came back down to 48CC.
Stock is closer to 50cc correct?
