VanWilder
Based on my 12.41 run NA which after extensive tuning should be quite a bit better now...what should I run on a 100 shot?! I have a bottle heater so pressure shouldn't be lower than 950psi...I also will be running a window switch not engaging the nitrous until 2nd gear from 3000 to 6000 rpm...I've read its not safe to spray off the line but have also read about numerous people doing it with no problems...should I think about spraying in 1st and if so what precautions should I take to make it as safe as possible?! Suspension wise I have BMR lowering springs (2in. drop) which I know dont help me, will have sway bar removed, rear bump stops will be cut, and I will be on 26x11.50-17 Bias Ply ET Streets...I will also be launching off a 2 step Chris Rose built into my tune at around 5500 rpm I believe...any thoughts?!
