10-12 retrofit on 05-09 s197 GT
mikeyfitz
Resident Fuktard
Houston, TX
I'd do it in a heart beat if they made a conversion. Hell if this works out I might do it
shark tales
Wiggle Wiggle Memeber
Charlotte, NC
Ok let's see.
Where to start.
First off. Almost every panel required some form of modification to fit.
I had everything loose so that I could adjust gaps and insure a better fit.
The hood required tons of little things to make worm. Hood latch from 05-09 only worked with 05-09 hood lock. Hood lock had to be drilled out to close gap and then adjusted hood latch to accommodate that.
The 2012 hood also has lower nozzles so the wiper covers where dremelled to accommodate that
I also connected the water supply to it using the T junction of 08 hood and then cut into the 12 lines
Here is where stuff got time consuming.
Bumper Fitment was dead on. I naturally used gt fender 12 brackets
I got lucky and the 08 fender bolt on holes lined up with the 12 bracket. So I used nuts and bolts to secure that.
Front12 bumper reinforcement went right into 08 crash bar they are the same part.
Lower valance is not a bolt on to the 12 bumper. What I did is see where they met and self tapped screws. It works perfect and it retains the lower rad shape on 05-09.
engine cover also lined up in holes to be secured but had to dremel trim by the hood prop mount and windshield wiper fluid pour.
Pics later on that. it looks OEM
The headlights. Yea they don't fit. So I had to cut out to make space. Long story short, the bottom mounting holes are the same for all years. The top mount, different story I drilled out my own holes.
Pics of the work I used my bros 5.0 to use it as a Template of the hole I needed to make it fit
10-12
05-09
Marked
Cut. I sanded an painted after.
While paint dried I also redid wiring.
Needless to say 12 hids don't work with the 08 harness. The turning signals and parking lights where required since the turning signals go into headlamps
Headlights in
Bumper Fitment with them
I'm going to be ordering new headlights tonight. I'm thinking 10 non hids black housing. And then just use my h11 hid kit on them and everything else will be plug and play.
Tightened everything down and reattatched side skirts. Which btw don't fit correctly with 12 fenders. I knew this would happen since they guys converting to 12 sides have to trim to fit. ImageUploadedByTapatalk1343535929.593140.jpg
cody2639
Texas
Nice work. It's going to be strange to see a 10+ front with a 05-09 rear lol
shark tales
Charlotte, NC
I told ya a lot of shit needed to be done and or modified lol...
Indeed lol
My idea was cut both a 05+ and a 10+ in the middle over the wheel well. And fab them together. Use the 05+ back half and the 10+ front half. That way you door line is the same and you can have the better looking front end
Sent from my MB855 using Tapatalk 2
I am going to do something similar but much simpler. I will draw it up on a diagram to share my ideas
lol tell me about it I keep staring hard
If you need extra parts, I have a 2010 hood on trying to sell. Excellent progress so far.
thank you
shark tales
Charlotte, NC
I ordered aftermarket projector headlights last night.
After that I'm def going for the cs and boss splitter.
I'm going to wash it and detail it some and add the fender badges
DRock
So you got the fenders to long up with the doors?
gil_t2
Love Nitro in the Morning
Northern Va
What are you going to do about the rear fender wells, to get them to match the front?
08 Vapor
Looking pretty nasty so far. Sick work! I hope you're prepared for the flood of internet forum copycats.
