2011 TSB Thread
KungFuHamster
Ft Worth
awesome.and since its a TSB, even if im not experiencing this problem, i can still bring it in to have the bulletin performed on my car yes?
Grimace427
Hellhound
Northern VA
TSB's are only for assisting technicians to diagnose problems that have been widespread. While your dealer may replace the trans fluid for you, don't count on it. Not every car will experience this problem, mine included.
In my experience here at a Benz dealer, less than 10% of cars experience even the most common TSB's, or DTB's(Dealer Technical Bulletin, aka Deet Dee Dee!) as we call them.
And FYI, recalls are only for safety related items. I can see the clutch issues falling under that category, but not the rough shifting issue.
jeff s
If you're not experiencing problems, would the fluid change still be recommended as prevention?
Strange that the original fluid is working fine in some and not in others.
I suspect there is still the clutch issue causing shifting problems too. Interesting.
heeltoe
San Diego,CA
If your car is not having the problem and the tech cannot duplicate it, they most likely will not repair it. Alot of people think just because there is a TSB out that it applies to there car- which is not accurate.
KungFuHamster
Ft Worth
thats what i figured. just wanted to double check before making any phone calls.
RSKtakR
Raymore MO
my trans has been whining in 1-4 for quite some time now, an just over the the weekend started grinding going into 5th gear, allready had the clutch, pedal assembly and master cyl replaced at 6700 miles (13k miles now). I called Ford customer care yesterday and got a case #, and will be taking my car to have them look at it AGAIN..I allready had them look at it once and they said the whine was normal, however when I go drive a 5.0 on thier lot it doesnt whine at all. How can this be normal when w/ past transmissions (T5) when it started whining it meant something was wrong w/ it yet this is normal for this trans? I wonder if the fluid change (that i have read other places DOESNT belong in this MT82) will get rid of the whine.
acrbill
thanks man! My car is in the shop for the fuel gauge TSB so I just left a message for the service guy about this TSB. I had mentioned to him that I was having a problem so hopefully this gets resolved for me.
Ivan 5.0
Still learning...
NoVA
Nice, thank you. Just set up an appointment for this Saturday - I've neem having the whole notchy and whinny trans issue since 500 miles on the clock - have ~2200 miles on it now. Last time I brought it in they said the whine was form the intake... *sigh*
ViciousJay
well i wanted to drain and refill seeing how im almost at 10K.... looks like im getting it done for free cuz i def have the notchy issue in the morning
Five Oh Brian
Mustang Guru
+1. A TSB doesn't mean you automatically get the fix - unless your car experiences the problem outlined in the TSB.
RSKtakR
Raymore MO
if the trans is doing the "common" whine allready, wont it just whine louder w/ the thinner trans fluid??
jmatero
This is specifically for folks experiencing shifting issues when the car is cold. If you are not one of those people, don't swap fluids. One side effect is that it causes whining from the tranny.
Fast351
I can't drive 55
Twin Cities, Minnesota
Just to be crystal clear here, this TSB DOES NOT address grinding into those gears, which is most likely a clutch issue.
I'm not holding my breath for Ford to admit that their clutch DESIGN is a problem for a growing number of M6 customers...
JDM74
Suffolk, Va
Got the TSB performed this afternoon. I'll let you know how it works tomorrow after I drive it to work in the cold. I am not convinced this is going to make all the notchyness go away. The fluid is noticeably thinner than the fluid that came out.
302
Atlanta GA
Subbed, let us know. :beerdrink:
Hufen
Houston
Yea definately interested to see how the thinner fluid works out, please let us know!
Trav4011
Hoosier Daddy?
Houma, LA
So confusing..
My trans came with QDC in it. It started whining/grinding within 1200 miles. It was rebuilt, and the tech installed the thicker QS fluid. Now, it doesn't grind, and shifts just fine.
GrabberBooGT
jmatero - how sure are you that this fluid will cause "whining." Didn't you have other work done at the same time that could be the cause?
JDM74
Suffolk, Va
Drove the car to work today, it was 49-50 degrees when I pulled out of the garage. Tranny shifted much better than it has in the past. No notchyness or grinding. No whining at all that I can tell. Car never whined before. Hopefully we will have a colder morning so I can see how it reacts to even cooler temps.
