I have a used Breather that goes into the oil fill on the 3V's. This part is used and in great condition, recently cleaned the filter and id good to go.
Metco Description:
Ford 2002 & Newer Modular V8 (with Twin Helix Mount)
(Includes 2005-2010 Mustang GT (4.6 3V) and 2011 Mustang GT (5.0 4V))
This valve cover breather assembly replaces the original oil fill tube found on the factory passenger side valve cover. The base is CNC-machined from billet aluminum for precise fit, and the included silicone gasket is specially designed to prevent oil seepage at the base of the breather. The filter base is microfinished for surface protection and good looks, and is easily hand-polished to a mirror-like appearance. The removable filter element is a high-quality reusable unit from S & B Filters, and it is securely retained in the filter base by a specially machined retention groove at the top of the base.
The purpose of this valve cover breather is to vent unwanted accumulation of pressure in the crankcase, and to provide maximum circulation of ambient air in the crankcase to reduce oil temperatures. The installation of this breather will contribute to increased engine oil life and reduce the possibility of failed engine seals resulting from excessive crankcase pressure. This breather will reduce the effectiveness of the vehicle's PCV system, and it is not emissions-legal.
Note 1: This Metco Motorsports Valve Cover Breather does not fit the 2003-2004 Mustang Cobra, the 2007 & newer Shelby GT500, or the 2003-2004 Mercury Marauder.
Item is locates in Downey, CA and is Used
Price$ 30 Shipped.
Metco Description:
Price$ 30 Shipped.
