TexasBlownV8
Formerly TexasBlownV6
Installed an iron-block 4.6, using whatever 'stock clutch' was on there, as it looked new and looked right. Bolted up a tr3650 to it, which was in the car and already worked before on a different engine. Used the thin metal spacer plate between the engine and transmission that was used on the previous engine.
When I release the clutch in any gear, there's a metallic tinking sound, and the transmission wont engage. There is a very slight reduction in engine rpms, so something is trying to engage a little bit.
Any suggestions? Seems like it is the wrong clutch or the transmission is too far away from the engine. Can I check anything through the bottom inspection hole that will help?
** How far out from the block should the clutch housing be at? ** (..the starter engages properly, by the way)
I know I'll have to drop the transmission to fix it, but what should I look for as far as pressure plate distance from the trans, clutch distance, etc?
..here's a pic of the clutch before engine was installed in the car...a part number is one it...hmm...
