*JZ*
I do know that there are 15+ individual tables for the TiVCT in these cars.
In English please?
Not without air operated valves...F1 teams have done this as they were losing control of the old-school valvetrain at the atmospheric revs they run.
http://en.wikipedia.org/wiki/Pneumatic_valve_springs
Its not likely that you will see an end user cam adjustable feature. The VCT is as mentioned before, incredibly complicated, and with the 15 or so cam timiming tables there are an equal number of borderline spark tables, because as the cam changes timing the engines requirement for spark will change too.
Not to mention, that there is also potential for catastrophic engine damage from changes in cam timing.........
cut fuel to one or two cylinders
I am glad of the decision to actually pursue true VVT cams with the 5.0 4V, the old method of locking them out I feel would be leaving power on the table.
The TracKey PCM software, installed by an authorized Ford dealer after a customer takes delivery of the car, adjusts variable cam timing, spark maps, engine braking, fuel control and other engine parameters – more than 200 in total – to provide a complete race car calibration. The result is an aggressive, race-bred driving experience all the way down to the lopey idle rumbling through the Boss quad exhaust.
“We installed the 302R software on the same PCM that held the stock Boss software,” says Seaman. “Then the controls engineers developed a software system to activate one or the other, depending upon which key was used to start the vehicle. Really, all the parts to make this work existed – the Ford MyKey® system was already using the PATS transceiver to perform specific actions based on the key used to start the car, and the PCM was flexible enough to handle multiple control modules. It was just putting everything together.”
