DSargent09
Get iT!
- Joined
- Feb 23, 2012
- Posts
- 706
- Reaction score
- 0
What you gain is confidence that you are getting the exact right amount of nitrous and fuel in each cylinder. We recommend that if you are going to be spraying large amounts of nitrous (over 250) a lot that the direct port is the best way to go to make sure that every cylinder is getting the correct amount of fuel and nitrous. If you are staying in the lower shot then a direct port can be a little over shooting it even though technically it is safer.
We have some guys that are spraying 300-350 on our plate no problems but they took the time to pull spark plugs and read them to get to that amount. They did the necessary time tuning and dialing the car in to make sure that it was safe. They also didn't jump right in a put a 350 shot in it. They worked the way up checking it every shot they went with.
The boss set up just depends on if you already have a manifold and what kind of direct port you want to do. (2 solenoid, 4 solenoid, distribution blocks or rails) Ill pm you and give you a ball park.
So would you say a 125 shot is "Safe" on a stock coyote, and what kit/setup would you recommend
