46addict
13726548
I know the point of balancing a wheel/tire assembly is to reduce vibrations, but I'm wondering if a wheel takes a lot of weight to balance, there's an underlying problem.
Today I went to have my used MT ET Radial Pros mounted on brand new Welds, and one of the wheels took 10.75 ounces to balance. The other wheel did not take as much. The tire tech used 26 quarter ounce weights on one end of the wheel, and 17 on the other. They were very busy today and I didn't want to have them dismount and remount if it's not something I need to worry about.
TireRack says the consensus is if it takes more than 1% of the wheel assembly to balance, there may be a problem. The wheel is 18lbs and the tire has to be at least 35 from what I felt, which would put me at 848 ounces. 10.75 would be over 1%. I need to put the assembly on a scale to be completely sure of my numbers. So can I run these at the track with this much weight? I haven't driven the car yet so I don't know if there are any vibrations.
