A-arm Brace mounting
spiral281
Zachary, La
would it be possible, or even recommended to weld in an a-arm brace?
found a granatelli a-arm brace for 38$ shipped...should i just bolt it in, or weld it?
94tbird
4R70W FTMFW
NY/NJ
its a GMS part. It would never touch my car.....
that being said bolt in would be just fine
Shotokan1509
CT
I would not weld it, would you weld a strut tower brace? If you needed access for something else it would be a pain. The oil drain is close to these braces, not sure how close on the GMS one. My CHE I can get the drain out, but its close enough to be in the oil stream when draining. If you are worried about that, I'd say look at the CHE version it has vertical AND horizontal bolts.. plus you can add the tq limiters.
ArizonaGT
Road Course Member
Phoenix, AZ
FRPP has one for $40, same as used on GT500 and the Convertible Mustangs.
Part Number is M-5025-A
