The Goal:
Show quality install of the AirLift Suspension system on a couple of S550's.
Supporting Parties:
Jay@Hypermotive and Jeremy@AirLift
The Staring Cast:
ProjectWhitemare and Dezl50
The Plan:
Purchase the Kit: DONE
Detail the Parts List: DONE
Plan Out the Mounting Solution: DONE
Mount the Tank, Manifold, and Relays:
Plan out and Route the Air Lines and Water Traps:
Swap out Front Strut Assembly for AirLift Strut Assembly:
Swap out Rear Spring and Shock for Airlift Shock and Bag Assembly:
Leak Test:
Final Inspection:
Road Test:
Redo Air Lines with Hard Lines:
Parts List for AirLift Suspension:
(1) - Performance Front Kit (Part # 78521)
(1) - Performance Rear Kit (Part # 78621)
(1) - AutoPilot V2 Digital Contoller, Manifold, Tank, and Compressor (Part # 27671)
(3) - 1/4 SMC Water Traps (Part # 21011)
(1) - VIAIR 380C Compressor (Part # 16380)
(2) - Compressor Isolator Kits (Part # 50714)
(1) - Autopilot V2 Second Compressor Integration Harness (Part # 27679)
(1) - Specialty Suspension 4 Gallon Seamless Air Tank
Valuable Sources:
S550 Install Manual
Setting Suggestions from S197
Scott's DIY AirLift Install Writeup on S197
Kimmer's DIY AirLift Install Writeup on S197
Inspirational Builds:
CVT Designs AirLift Setup for S550 for Matt Guerro (@mattyopattyo)
Open Road Tuning AirLift Setup for S550 for @5liter_goblin
Before Pics (Whitemare):
Before Pics (Dezl50):
Supporting Parties:
The Staring Cast:
The Plan:
Leak Test:
Final Inspection:
Road Test:
Valuable Sources:
S550 Install Manual
Stage 3 Motorsports AirLift Install on 2015 S550 EcoBoost:
CJ Pony Parts AirLift Install on 2014 GT500:
