That is the same ford pump with higher presure plug because the spring is the same i've seen many fail
This isn't the one with the billet backing plate is it? If so, I thought it had a different Part #?
That is the same ford pump with higher preasure plug because the spring is the same i've seen many fail, i just use melling pumps 10340 (regular gears but never seen one fail) or 10227 with billet gears
