LAStang1234
----------DSL----------
We have a customer with a 2013 that he just installed a bunch of suspension parts on it from us. Everything worked perfect for him with zero issues.
Lol this post was pretty random!
Maybe your springs have just settled a little more since its got some age on it and hers is new and has not settled yet.
Tire wear
I wonder what options get you the FFCCs?
i wonder if it is as simple as hers being a GT Premium and mine is a GT (base model) that change puts leather and a heavier/better stereo in the car so maybe ford decided that increase in weight requires stiffer springs?
if this were true then loading the back of a pickup truck with a ton of gravel wouldn't change the ride heightStiffness of springs alone will not delegate ride height. Length of spring will also have to be taken into account. What little bit if weight that would be added from leather vs cloth and upgraded stereo I highly doubt that being the reason to have a seperate spring manufactured.
No, what you said is te spring stiffness will not effect ride height. Now your contradicting yourselfStiffness of a spring is known as the value k.
F=delta_x*k where delta_x is the displacement produced by the force acting on the spring.
In your situation you stated that the weight of the gravel, or the force exerted by the mass of the gravel multiplied by the acceleration due to gravity.
Now position will also be delegated by the starting length of the spring. Hence, as I was saying earlier, spring stiffness is not the only factor of the equation. If the 2013s spring is originally an inch longer then the ride height will be an inch higher if it's in the same car even if the spring rates are the same.
