neema
Thought I'd share. Linea Corse Lemans 19x10 et43 on all four corners with 285/35/19 Kumho Ecsta XS tires. 15mm spacers needed up front to clear the brembos. 1.8º of camber up front. The car is lowered around 2". kw clubsport coilovers. Better pictures coming soon.
FYI these should fit really well with non-brembo cars, assuming they have more brake caliper clearance. you may not even need a spacer at all.
