No idea if it's available in a size for you, but the Dunlop Star Spec is a phenomenal tire.
Michelin PS2's or Im having good luck with hankook ventus v12's.
That's what I'm afraid of. I'm getting ready to supercharge the car and I'm afraid these just aren't going to do well with that setup.Loved the 555s while N/A and under 500hp. Once I went over 500hp they're worthless. I'm running 555r and they're fine in a straight line. If I change lanes and hit the pedal, even a little bit, the rear end gets squirly, so I have to make sure I've gotten the car straight before punching it. I'm also looking for a good tire aside from the M/T DR which works great but not so much in the rain.
If you want a cheaper alternative to Michelin, you can try the BFG KDW2's. The plus is they have excellent wet performance and the tread lasts a long time (in addition to looking cool).
I've got these. They're friggin amazing
I hear you. I was out at a friend's house the other day and did a burnout when I left and the car literally wouldn't move and I'm still N/A. I really wasn't meaning to spin as long as I did, but the car simply wouldn't stop. Second wasn't much better.You have good instinct here... they suck (555s). I literally hit the rev limiter (7.2K) the other day with my auto. Spinning all the way to the limiter in 1,2,3 and barely moving. It was not intended. Just would not hook once they started to spin. Hit fourth spun some but finally started to move. Then it downshifted back to 3rd. Pretty much sucked. Those nittos can suck a fart out of my ass. I literally can downshift off the converter on a nice surface at almost 80 and the car spins the shit out of the tires. They were ok on stock power but not so much now.
Looking at options myself, but for traction dont think they are going to be 20's for long. Just not much way around the 18's. Weight is another problem with mine.
I have these as well and your are right.. they are amazing.... and also the noisiest tires I have ever owned...They are louder than my exhaust.
No fans of the Toyo Proxes R888 ?
Not sure how some of these folks are doing it, I have 750rwhp on 93 and over 800 on the race gas, and this doesnt happen to me.Here's a tip for you guys supposedly doing burnouts through 4th gear:
LET OFF THE THROTTLE
I think people exagerate. From a dead stop, sure I could carry a spin through 4th, but I cant just do a 40-60 mph roll on in 4th and spin em.
Without any effort I spin the crap out of them from 40+ on a roll. Actually think I have a vid. Driver has everything to do with it lol. Obviously I stabbed it on a less than ideal and cool surface just waiting for it to grab. Once they started to spin not much was going to stop other than the pedal.
I still have shiity 255/50/20's in a 555s not drag for my street tires.. way too narrow/heavy. I am limited by a damn 9" rim. They are "forged" but I think they meant forged in lead. Tire/wheel combo is 63lbs each. I have not found a rim I really want that is light weight (without spending a few thousand bucks on just rims). Over 600 at the tire (on pump) pretty easy to do (on my lousy setup atleast).
My Hoosier QTP DR's will spin at the track if I have the 2step up too high (driver mod needed lol). About 6 passes on those and they need screws now. Once they start to spin 0n the rim then they probably won't stop. They were mounted with water and no soap. We had pressure down to IIRC 16lbs and they spun the rim almost 1/4 turn on the first couple passes. When they finally came around they spun almost 1/2 turn.. Really needed more pressure but higher and they spun after the track started to wear down (lots of radial tire cars that night).
I also have vct locked out on a PD blower and I get tons of torque down low. That does not help my problem much. The crank gears only retarded 2* right now and would benefit all around by retarding them more.
