I researched brake bias to death.
Multiple parties told me not to screw with the rear brakes...that includes the head test driver at Roush Performance and the Stop-Tech engineers. Brake pad upgrades, stainless steel lines, slotted or dimpled rear rotors, and of course high-performance fluid are fine, but swapping the rear to different calipers or changing rear rotor diameter can definitely screw up bias.
Products like the Stop-tech 4 and 6 piston calipers (ST-40 and ST-60) along with the associated 14" front rotors, Brembo GT500 brakes, BAER front brake upgrades, etc. are all designed to NOT screw up bias in these cars.
Think of it this way: A stock GT comes with X amount of bias. The stock GT brakes, in an emergency stop on a car with cool brakes, will stop in X distance, with anti-skid modulating. The main limit in my scenario is tire contact patch, tire compound, inflation, and surface...IE we are limited by tire traction and anti-skid modulation when they do lock up.
Adding high-performance brakes (bigger rotors, upgraded pads, SS lines, fluid, slotted floating rotors) is done mostly to dissipate heat better, provide better brake application feel (decrease pedal mush), and prevent fluid boil / brake fade / brake loss when things do get hot.
Stop-Tech and Brembo did their homework so as to not upset the bias, but still make a product that looks sexy and can dissipate a ton of heat.
Changing the rear rotor diameter or hydraulic balance of the rear calipers via a branding change, if using a brand that was not specifically designed to NOT change bias, can cause instability in turns when braking.
So...most guys will be fine with some fancy paint on the rear calipers to sex them up a bit, a change to a good pad, some SS lines, and, if desired, some same-diameter slotted rotors so as to not screw up bias. If you want more than that, do your homework very, very carefully.
Again, Stop-Tech and Roush advised me AGAINST changing rear calipers or rotor diameter. I'll see if my Roush contact can tell me how bias is controlled on the S197.
