Not your typical application, but I have been searching the web for days without a clear answer.
What I am wondering is if the "Brembo upgrade package" caliper bolts up to the standard GT caliper mounting bracket on the OEM 13.2" front rotors, or if they have their own custom bracket.
Application is actually in to a fairly custom '66 coupe that will be likely running an 18x9" rim and 255/265 tires. Since I will be about 600lbs lighter than you guys I am thinking the OEM brembo caliper would be a nice (and net less expensive) brake upgrade and allow me to stay 18's vs the GT500 set up.
Thanks in advance
Fej
Thanks in advance
Fej
