For quite a while now I've been running breathers. Left the check valve in and never removed it. Also have a cfm oil cap breather with a check ball inside.
I may need to pass emissions (OBD2 only) in NV next year and on the off hand chance they poke around under hood am thinking about going to a catch can setup with the oem filler cap back on.
I am assuming since that type of setup is not vented to atmosphere it shouldn't be a problem. Is that accurate?
