claudermilk
It's about time to start a build thread, I guess. This will be a slow-moving, and probably relatively unimpressive build in the context of this forum, but what the heck, I'll make you read/ignore my ramblings all the same.
So, to start with the basics. The car is a '13 base GT with the Brembo package, Recaro seats, and 3.73 axle. It was bought new on the 4th of July (because what better day to buy an American muscle car?) in 2012. The plan has been DD also seeing autocross and occasional track day duty.
Up until now, I've left it pretty much stock while familiarizing myself with the platform and identifying improvements I wanted to make. The first mods were mainly cosmentic. Tint, Roush axle-backs so you can hear the car, AEM air filter so I'm not replacing paper ones, and an Epco shift knob just because.
First was to acclimate myself to a 420HP RWD beast after coming from decades in FWD & much lower-power cars. So I spent the first year just doing autocrosses and stinking up the place. At least I wasn't last or DNF. I also jumped at the opportunity to attend an Evolution School event which was a day & money well spent.
I recently ran my first track day and really got a sense of the compromises Ford made to the suspension. Sure, the S197 platform is a great start, but even those uprated Brembo springs were way too soft. Massive nose dive under braking, lots of squat under acceleration, and the car heeled over in turns. I missed being lowered.
Even with that now-obvious limitation, I managed to win the All-American Sunday event at Goodguys. But now the suspension movement was bugging me.
So now for the first actual performance upgrade & start improving hte handling of the car. I spent this last weekend installing Koni Sport dampers, Steeda Sport springs, Steeda adjustable panhard bar & brace, and Vorshlag camber plates.
Before
After
Installed parts
Getting the boy involved
One small isuue I ran into (aside from snapping an 18mm socket getting the spindle bolts off) was the combination of stock strut bar + Moroso oil separator bracket + Vorshlag CC plates = no bueno. The bolts are too short to handle all those layers. For now, I have it ghetto-rigged with zip ties, but need to come up with a permanent solution. Either find a different separator, or come up with a custom bracket bolting somewhere else.
The initial test drive shows a much improved car. The changes appear to have done exactly what I wanted. Dive, squat, and roll are much reduced to non-existent. I am getting a lot more road surface feedback now. I'm still experimenting with the Koni's settings, but full soft does indeed seem very close to stock ride quality, and full stiff is not kidney-busting. The big surprise is running over a section of freeway that is a nasty washboard surface, the new parts ride smoother over much of it than stock.
The next project is brakes. Vorshlag SS lines, Motul 600 fluid, and Carbotech Bobcat pads going on. I have XP10/XP8 ready for track days, and a spare set of Centric front rotors just in case. I ran out of time to get these installed this time around and encountered stuck rotors on the rear. Edit: Done!
There are many future plans that will keep me busy buying and installing for a while.
Current Parts
Performance:
Roush Axlebacks
AEM dry flow air filter
Bob's Auto Sport oil separator
Koni Sport dampers
Vorshlag CC plates
Steeda adjustable Panhard bar & brace
Vorshlag SS brake lines
Motul RB600 fluid
Carbotech pads (1521 street & XP10/XP8 track)
Bob's Auto Sport axle reservoir
Cosmetic:
LED running lights & map lights
Redline Tuning hood strut
Epco ball shift knob
Planned Parts
Performance:
Brake cooling ducts
Watts link
Coilovers
MGW shifter
Whiteline trans mount bushing
T-2R diff
Adjustable sway bars
Cosmetic:
Steeda side splitters
GT500 wing
RTR rear license mount
Street Scene chin spoiler
Other:
5/6-point harness & Corbeau harness bar or Watson 4-point
Blowfish tow hook
Before
After
Installed parts
Current Parts
Performance:
Roush Axlebacks
Koni Sport dampers
Vorshlag CC plates
Motul RB600 fluid
Cosmetic:
Planned Parts
Performance:
Brake cooling ducts
Watts link
Coilovers
MGW shifter
T-2R diff
Cosmetic:
GT500 wing
Other:
Blowfish tow hook
