BadHabit2Break
So I have been wanting to do this, but all the ones I have seen are $60 and plug and play. $60 is alot, so I did it for $20 and about 30 minutes.
Parts:
3rd Brake Light Flasher
http://www.xdponline.com/index.php?...id=180&zenid=af27c119150f3bb1eccd96d0a0ef103d
Download Manual:
http://www.xdponline.com/documentation/UnvBrakeFlasher36Install.pdf
Tools:
Black Electrical Tape
Wire Cutters / Strippers / Crimpers
Pliers / Small Channel Locks
Small straight head screwdriver
How To:
So order the flasher from the link above. Should look like this when it comes in
It's about the size of a dime with some wires coming out.
So pop your trunk
Pull these 2 tabs. There is one on each side.
Pull the carpet down and slide the yellow handle through the opening in the carpet. This will give you acess to the 3rd brake light.
Unplug the connector from the light.
The Black wire is the ground, Yellow is the 12v power when the brakes are applied.
Cut the Yellow wire and strip the ends
Connect the red wire from the flasher to the Yellow wire on the harness end of the brake light wires.
Connect the Yellow wire from the flasher to the Yellow wire on the connector end of the brake light wire.
Connect the Black wire from the flasher to the Black wire on the brake light harness.
Now test to make sure the Green LED on the flasher lights up when you push the brake.
Helps to have a person in the car pushing the brake pedal.
LED is on top corner of flasher. Its very small.
Once it is confirmed that it works, you will then need to program it. Just tap the 2 white wires together to change modes till you get the one you want.
Once you have it set, tape up everything nice and neat.
Then stand back and admire your hard work and $40 savings.
Parts:
Download Manual:
Tools:
How To:
So pop your trunk
