Drag radials
1FastS197
Hickory MS
okay, i have a set of 305/35/18 Nitto Drag Radials... anybody know i they will fit on a 8.5 wide wheel? i also have 2 GT500 stockers... not sure if they are wider than the 8.5" wheels i have on there...
will they fit on a 8.5... yes... is it smart, should you do it.... NO
GT500 - Wheels as mentioned are 9.5 (at least the rears I know of for sure) on that size you can use the 305s
1FastS197
Hickory MS
well, i have been thinking of cutting the 8.5's and making them an inch wider... kinda worried about backspacing then tho...
they will widen to the inside.... backspace should not be an issue
1FastS197
Hickory MS
oh okay, i think these are +45 but i am gonna check and see what they are exactly... thanks for the help...
retfr8flyr
The Old One
Providence Forge, VA
The most backspacing you want is about 7 1/4 inches anything more that that and you start running into clearance problems.
Earl
