Kaldar142
Great product either way, definitely improves ride quality
TANSTAAFL: The Watts is heavier, more expensive, and tends to concentrate all of the forces on a single point, which if improperly designed, fails with dramatic consequences... I am NOT saying the Fays exhibits this issue, but it is endemic to the Watts design.
Clear as mud, eh?
It is heavier, but not as much as many folks think. Fays2 links (which I have on my car and supplied Sleeper08 with) use billet aluminum bellcranks, and aluminum arms. The frame is steel, as are the axle clamp. But then again, the stock PHB and brace are as well. And the entire frame, bellcrank, two of the 4 rod-ends and half the arms are all sprung weight. There very very little increase in unsprung mass. And even having said that an entire Watts is less than 30 pounds boxed up. It's more like 27 or so including all the hardware. The stock stuff is around 10 pounds. So yes, there is weight---it's not 50 pounds. It's far from all unsprung, and if you are going to carry it down low and to the rear ain't a bad place.
As for the stresses being up on a single point. That's true. But it's also why a grade 8 bolt 3/4" in diameter is used for the propeller/bellcrank. That way, WAY bigger than any bolt that holds the PHB in place. In fact the Tensile strength of that bolt is over 50,000 PSI.
Yes there were some bolt failures on Saleen watts links, but they were largely due to binding IMHO. The Fays2 bellcrank uses not only one, but TWO sealed bearings to insure the bellcrank does not bind and put any undue stress on the bolt.
I have Watts links on both my Mustang and my Camaro. I wouldn't trade them for PHB now that I have felt the difference. No way, no how. PHB's are nice and cheap but not exactly a perfect design.
not trying to be a smartass or anything but from what i am looking at, the tensile (pulling) strength wouldnt be an issue. from what i see it looks like shearing would be a problem. (though it is very hard to shear a 3/4" bolt, these things do happen). im not trying to put down the system or anything, im just wondering if the way im looking at it is right. the bolt in question is in the middle correct? would this be a problem that tensile strength would be brought into play? im trying to learn about road racing and such and i really just want to know if im looking at this correctly or if im going to be thought an idiot for my questions
Maybe someone can find the shear limit on a Grade 8 bolt.... I was simply pointing out the it ain't weak, and in fact is about double what the big 3/4" rod-ends are in that regard.
And let's say anyone had a true reason to be worried. Replace the bolt say, yearly. What can it cost? $10? Small price to pay for peace of mind if you are truly worried about it. Not one of those bolts have broken. And fwiw, that includes a lot of cars that can pull well constant 1.2g + steady state and have broken a lot of other things up and including shearing an axle shaft just outside of the differential.
Sam Strano
6x SCCA National Champion
Owner: Strano Performance Parts
Hi Sam,
LOL! I see you have done a 180 with regard to the value of running a Watt's link on your S197 chassis just as I had to do once I drove a car with a Watt' link installed. It was just a matter of time I suppose.
Cheers/Chip[/QUOTE
Hey Chip
What do you think of not having an adjustable roll center ? If you had one that was adjustable do you think it would make a difference with your set up ?
Thanks
Hi Sam,
Cheers/Chip
Hey Chip
Thanks
Hi Sam,
Cheers/Chip
