pcdrj
How should you keep rod ends lubed? WD40? Lol
I use chassis lube on any bushed connections and WD-40 on bolts, rod ends, etc.
MOST of the rod ends on the market today are teflon-bushed, and require no lubrication. That said, I do use WD40 periodically on them. Not as a lube per-se, but to put a moisture barrier up and to flush out any contaminants.
