Subbing.......
I was thinking about this exact swap when the DOB kits first came out.
RH
RH
I did try to call and text you a few days ago,your mail box was not set up.
Jim
What was the issue?We took a look at it. It’s not possible with a GT500 blower.
What was the issue?
I think the vast majority of heat comes from the block .
We have a solution for that. We're working on it right now.
Elaboration available?
Nope, top secret for now.
I can say that the solution is relatively cheap, easy to install and drops IAT’s 25-30deg though.
We are targeting GT500’s first (Gt500 guys spend more $$$), then we will do it for the 3v’s. I’m not sure if the Roush will need anything special. If it does its no big deal, it will just take a little longer to make available. Were hoping to have the “kits” ready by spring at the latest.
I’m guessing we are going to sell a shedload of them. I big HE and water pump will barely get you a 25-30deg drop in IAT’s and really does nothing for heat soak.
Maybe I'm missing something, but I would think the only other way to lower IATs would be injection, or a secondary HE setup with some sort of relay controlled valve that would switch between a primary and secondary HE setup depending on the fluid temp of each, if that makes sense. I'm in for curiousity, you've peaked my interest.
It’s MUCH, MUCH simpler than all that. Sometimes the best solutions are.
The idea is simple, and easy to do. That is why I’m not “advertising”. Someone will copy it (probably made in China) eventually. I’m giving myself the biggest head start I can.
Remember the post from the good ol boy I copied, who set up a small nozzle to spray E85 upstream from the intake to cool it down? I wonder if anyone has played around with that. How much would it take, and how hard to incorparate into tune?
I may skip on PD blowers all together. S&H is changing my heart with a nice 1000hp + twin turbo kit with *oiless* ceramic 62mm Comp turbos coming out soon that doesn't resemble any of the turbo pile of piping mess and heat under the hood with other systems. Very impressed so far. I'm sick of heat soak and it's hard to avoid pouncing out on the street with any PD blower.
We shall see by December what new FI project awaits for me to install. Time to feed this big stroker by damn!
