01mingreyvert
- Joined
- May 13, 2007
- Posts
- 202
- Reaction score
- 0
When cruising part throttle I get 8 to 10 lbs. Go wot and it drops to 1 lb. Checked for leaks none visable. Running off wastegate it should stay at 10 lbs. Just did new shortblock, hot rod cams and pi 3000 converter. Thinking something is up with the wastegate. Any thoughts. Hellion 62mm turbo converted to blow thru before the shortblock. Was making 12lbs before the motor cams and converter.
