How much is a McLeod RXT clutch for a 2010 GT500?
MrClean
Marc; but I go by MrClean
Friendswood, TX
Think I might wanna do this before swapping to a smaller pulley....
silverpoison
SoCal
Around $900 Plus Shipping..
you must change the flywheel when going with this clutch, the stock flywheel will not work with it, if you do street only or drag racing go with a light steel flywheel, if you do road racing go with a fidanza aluminum flywheel.
Ed
wazme
is there any1 who can help me with the body layout of 2010 Mustang GT 500 plssssssss
bpmurr
Hampstead, MD
What's the difference between these two units?
http://www.lethalperformance.com/tr...rxt-street-twin-disc-clutch-26-spline-p-30508
http://www.lethalperformance.com/tr...street-twin-disc-clutchsteel-flywheel-p-30510
It also says you need a new slave cylinder as well.
http://www.lethalperformance.com/20...helby-gt500-adjustable-slave-cylinder-p-27891
I'm assuming this is the flywheel needed for street use.
http://www.lethalperformance.com/20...gt500-lightened-steel-flywheel-8-bolt-p-30517
This is assuming that McLeod doesn't have a 2010-11 specific unit yet.
MrClean
Friendswood, TX
Ed
Thanks for the info, Ed. Why is the light steel good for drag racing and why is the aluminum fidanza better for road racing? I don't go to either type of track, but I guess I'd fall into the drag-racing category since that's essentially what I'd be doing against an uglymero on the street...
MrClean
Friendswood, TX
Wow:
"Before we wrap up this section on flywheels, it's worth looking at just how much weight we would have to remove from the car itself to equal the effect of the 20-pound-lighter flywheel. If the heavy flywheel was retained, then the car--to equal the First-gear acceleration given by the light flywheel--would have to be reduced by 272 pounds. The equivalency figure for Second gear would be 187 pounds; Third, 127 pounds; and Fourth, 98 pounds. At this point, we think we can safely say lighter is better!"
I dare say a McLeod clutch and aluminum Fidanza flywheel are going to be the next upprade....
bpmurr
Hampstead, MD
Wow:
Why not the McLeod flywheel as well? Wouldn't be better to use the same company for both?
bigray327
League City, Texas
RXT with the McLeod steel flywheel here. I used to have a Ram clutch and Ram aluminum flywheel, and I like this combo better for the street. RPMs stay more manageable.
AJ
US Muscle, AUS Hustle....
We still have a Mcleod group buy going for the next couple days ;)
blacknlte
Odessa, Tx
Youll also need a throw out bearing from 07-09 cause the 2010 are different and the clutch companys havent made the design changes yet.
MrClean
Friendswood, TX
that's a valid point....engineered compatibility and idle quality
thanks...I'm sure Lethal can provide the whole enchilada at a competitive price.
