NotaHybrid
I'm slow
I'd be making a phone call to cancel an order right now if I had done that
Just don't be that guy that is lying because he is too scared to embrace a mistake. You must embrace The Stupid.
So far, I've had no reason to go beyond +1.5 turns front and +1.25 turns rear relative to full soft even for track days. I'm still on the OE springs. More than one instructor has commented that the car is composed at those settings (and with the rest of the setup).
With the wheel & tire upgrade (that hasn't seen track time yet), I expect I might increase those settings a little.
For the street, it depends. With my wife present and a lot of driving on rough pavement expected, about +3/8 and +1/8 turn. Alone, anywhere from +3/4 & +1/2 to +1 & +3/4.
Norm
Word of the day: critical damping.
How does one achieve critical damping (or, rather, a desired percentage of it) other than via a shock dyno? Seems to me there's far too much going on in the suspension for anyone other than a complete expert to be able to dial in dampers with any real degree of precision.
It's not as hard as you'd figure. Start on soft and work your way up depending on the transitional response the car has. The Neil Roberts book has a fantastic section on making shocks adjustments, complete with table of cause/effect.
Couple things to consider...you have to be systematic, and only make one change (front or rear) at a time. Also, without a good racing seat, adjusting shocks becomes exponentially more difficult. All of these adjustments rely on your ass. If it's held in place, good. If not, good luck.
You can't.
Why would you want it that soft?
Well, sure, you can (or should be able to) tell the difference between those, but the question is how you tell that you've achieved the optimal damping coefficient.Yes......even if its not you can tell when they are wrong. Run back to back on full soft and full stiff.
First off, you need to define "optimal." This can either be objective or subjective...
Optimal damping for handling can objectively be defined by net lap time.
Optimal damping for ride quality can subjectively be defined by driver's comfort.
Optimal damping for a dual-purpose car will, I think, NECESSARILY be subjective.
So, how do you tell? On track, keep tweaking until ANY adjustment yields slower lap times. On the street, keep tweaking until you've turned your corner-carver into a Cadillac Fleetwood. Dual-purpose car? It's a compromise by definition, so find the middle ground you're happiest with, and call it a day.
Note that even with subjective testing on track, driver preference plays into things. One driver will prefer a looser car, another will prefer a tighter car. Different settings will achieve the net lowest lap time for each driver. Clear as mud, right?
Heh. Yep.
Of course, the problem with using lap times as a metric for tweaking is that it presumes that the amount of difference the changes make exceeds the natural variability in the lap times. For someone like me, that natural variability is going to be quite large, on the order of a second or so per lap at a track like Laguna Seca. Consistent lap times can only occur if you do everything the same every time, something that I have trouble doing (as I learned at my track event at Laguna Seca, something I have yet to do a writeup on. The upshot is that the consistency problems I have there in real life are identical to the ones I have in Gran Turismo). Only then, I expect, will anything but the largest changes become apparent.
Yes, for an overall lap time, you are correct. However with any good data acquisition setup, you'll be able to define and look at sector times, which are arguably just as good. Even in a 20-minute session, you should be able to find 3-4 instances of a "good" run through any given corner or set of corners, and that can be used as the comparison basis for between-session tweaking.At an HPDE, it's even worse, because chances are you're contending with traffic, and that will introduce even more variability.
In essence, I don't see any reasonable way to achieve such a thing on the basis of lap times until the driver is really good and has more or less exclusive access to a track.
Not necessarily. The essence of "ride quality" is isolation between the driver and the pavement. The essence of "maximum effort" is the elimination of that isolation. In a Caddy Fleetwood, the car just floats over the bumps, and when turning-in, will spend quite a bit of energy rolling over, all of which isolates the driver from the bumps and g-forces, or at least slows the onset. On a 996 (or fill in your favorite hyper-tuned supercar) though, you can practically feel the grain of the asphalt in your butt, and when you turn-in, it is IMMEDIATE, and you feel all of it.Also, based on what I've been reading about damping, I'm no longer sure that the compromise between handling and ride comfort is as great as has been claimed. As I said, the most effective (and controllable, I should think) suspension with respect to maintaining a corner is going to be the one that keeps the tires planted on the road while minimizing the amount of tire-to-pavement force variation due to bumps. Such a thing would of necessity result in maximum ride quality (smoothness of the chassis over bumps), as any force variation that is transmitted to the chassis must originate from or generate force variations between the tires and the pavement.
Possible, but that same responsiveness is primarily (I think) created by the rate of loading in the transition between straight-line and turned. That has nothing to do with springs, and everything to do with dampers. A softly-sprung car is not, by definition, impossible to turn crisply. High damper forces will delay the roll, effectively stiffening up the wheel rate until it bleeds down and steady-state is achieved. The forces acting on the chassis as it begins to turn haven't changed. It's still F=MA. What HAS changed is the instantaneous loading of the suspension under the car, and that's governed by the dampers.It may be that steering responsiveness is a compromise for that, but I would think that would be determined primarily by spring rates than by dampers. As long as the transition time from one steady state to another is minimized (as it would be with a damping coefficient in the range I'm thinking of here), then steering responsiveness should be maximized as well.
And therein lies the rub. If you have clean laps to look at, and you're getting a one-second (or more) variability in lap time, then IMO worrying about achieving critical damping is akin to obsessing over the shade of red that you're painting the barn while it's on fire... Remember the mantra: Fix the driver first, THEN start working on the car once you have idenitified one specific thing about the chassis that is genuinely holding back the driver...
Bottom line, though, is that I think worrying about achieving critical damping, while desirable, is shooting for that last 1/2% of performance, when the first 35% hasn't been achieved, at least at this point. Even with a "pro driver" in the seat, if the AS% and geometry issues aren't fixed first (for example), the absolute perfect damper rates could be lost in the "noise." At least in comparison to "close enough," anyway.
Regarding the driver: Honestly, for anything beyond the absolute basics, until you can get within a 1/10th or two per mile of track, any changes you make are going to be masked by driver error. I'm not saying they're not worth studying, but the focus still needs to be on the driver at that level.
If we assume that the designers of both vehicles A) know the spring rates to be used and B) can calculate "critical damping," then we have a problem, since the characteristics of the two cars are radically different. IMO, it's one of the following:
1) Either the gangsters in Detroit or the engineers in Bavaria are unable to use a calculator and got the math wrong. Very unlikely.
2) "Responsiveness" and "Comfort" are diametrically opposed goals requiring radically different damper tuning. Very likely.
3) "Critical damping" isn't so critical. Possible.
If we define critical damping as simple control over the springs, to prevent excess vehicle oscillation after suspension jounce or rebound, then neither car really meets that definition.
Your point about springs is well taken, I may add. Yes, given that force remains the same, the higher spring rate will "take a set" more quickly. I'll also go as far as to say that the higher spring rate MAY also contribute to more NVH, and thus lessen the "ride quality."
Speaking of somebody who HAS rebound-adjustable dampers, that little knob does make one HELL of a difference to both lap times and lack of bloody urine. I have found that my track settings are miserable on the street, and my street settings are so bad on track that "pathetic" would be too kind a word. Note that this is with rebound-adjustability only. I can only imagine (and drool over) what kind of control you would have with triples, where you can completely control the low-speed circuit, AND have some control over the high-speed circuit as well...
I think your plan of going directly to coil-overs is the right one. You can simply and easily (cheaply!) play with spring rates, and if you get triples, you can play with damper curves to your heart's content. Either way, I think you'll find you'll need very different settings to really carve corners and to have a nice, cushy ride.
So, what are you waiting for???
Oh, and driver mod: Seat time is everything. The more comfortable you are out on track, and the more experience you have, the less you have to think about what you're doing, and the more consistent you become. THAT is where changes made to the car will show up.
Basics, like getting enough negative camber are not about going faster necessarily, you're going to do that anyway as you accumulate experience, but are about protecting the tires. In your case, doing camber and swapping the dampers out will accomplish the same thing.
Get the camber you need, find a good compromise setting on the dampers, and then LEAVE THEM ALONE!! Resist the urge to touch them unless and until you can say with complete honestly that you are driving beyond the capability of the suspension tuning to support. Then prove it to yourself by ripping off a string of laps where each sector is consistent in time. THEN tune and assess the validity of the change.
Don't bother with lap times or data acquisition, though, until you have figured out that whole pesky "outside-inside-outside" thing and have pretty consistent (deep!) braking points. Lap times and data are great for refining, but you have to have the basics down first. Oh, and run video at the same time. NOTHING is more frustrating that looking at the data and realizing that you just cut 2/10ths out of a corner but not knowing how you did it.... Ask me how I know... And no, the resolution (GPS position) on most data systems is NOT close enough to judge the difference between turn-in points that are 2' or so apart, particularly in different sessions or on different days. That's up to net lap times and the video camera.
