Koni yellows pair best with...
csamsh
OKC
A spherical UCA can really transform the way the car reacts to power, at the cost of some noise. Necessary? No. Obvious big change in handling? Yes.
Mark Aubele
What specific improvement did you notice? Probably my next modification. Still have all stock arms in rear (have rod ended panhard).
csamsh
OKC
Biggest improvements- rear end behavior under power-oversteer and lift off oversteer is much more consistent and predictable. Also, far less hysteresis through the drivetrain when shifting and launching.
I had a spherical in the differential as well. I imagine the improvement is less pronounced with anything but a spherical there.
cm581978
NJ
Now do the Yellow only have adjustablilty with rebound? I have the P springs and a year latter, still cannot find a comfy ride.
Norm Peterson
corner barstool sitter
RIP - You will be missed
Koni yellows are nominally rebound-adjustable only. But there may be a little crosstalk between rebound adjustments and bump damping down at very low piston speeds, say under 1 in/sec. Full soft to only a little off soft is probably the range you want to work in for minimizing crosstalk effects.
Norm
kona302
south texas
Whose thread was it in for the spherical in the differential ? I'm wondering if it can be a DIY or what tools I would need.
Kobie
DIY with the proper tools and a lot of swearing!
csamsh
OKC
Me. Well I was one anyway. Job is a PITA. I didn't want to mess with it on jackstands so I paid a pro to do it.
Need a 58mm socket to tighten it if you use the Steeda one.
Here's the part I used
http://www.steeda.com/steeda-mustang-spherical-bearing-555-4104/
Created a tool to remove stock bushing
Turned the 58mm socket down a lathe so it would fit. I really don't know how you'd get it tight otherwise...loctite and pray maybe?
New and old
Installed
13726548
GA
Are relo brackets a necessity after lowering even if there is no wheel hop? I noticed my LCAs are no longer parallel after lowering the car 2.2" in the rear.
Norm Peterson
If you're getting good enough launch grip (not too much wheelspin for the way you drive), you don't have an acceleration problem that relos can solve.
If you like driving the corners hard enough, you might want to install the brackets if the tail gets too loose too easily should you have to suddenly lift off the throttle in a corner. If this is the case, only a mild setting (top relo holes) should be enough of a tweak in most street-driving cases.
Norm
claudermilk
SoCal
I was going to say BS, but looked more closely at the chart. Yep Konis shown as not pairing well with Big Red. All is good. ;) :lol2:
