OK, I searched on here about this to no avail. My 2 step has 3 wires, black, blue, and blue/white. The black wire is connected to the ground next to the battery. The blue is not used and capped. The blue/white wire i have connected on the bottom clutch switch on the black wire inline. Isn't working.
On my first attempt I had the blue/white wire connected to the blue/yellow wire on the clutch switch and the 2 stepped worked when the clutch pedal was up but didn't work when the clutch was pushed in. Tried switching the black and gray wire packs under the hood, that didn't work.
What wires go where? So frustrated, please help!
