My experience with my 2012 GT500 and the second gear grind issue
19COBRA93
Ford Racing
Clinton, Ut
I ran the torque limiter solution by them, they'd be willing to try it, but after the new parts arrive. As of right now, they are listed as back ordered.
So whatever part # is in the system for the latest gt500 clutch/shifter, theyre saying they can't get them and don't know when.
If you can get the clutch part number from them, I'd like to know it. The clutch I just got here was also backordered but finally arrived. If it happens to be the part number they're waiting on, I'd be glad to sell it to your dealer as I no longer need it. Most likely it is not though.
Seer
Able to check and see if there is a newer part # than the one you have?
19COBRA93
Ford Racing
Clinton, Ut
According to Ford DOESII (Ford parts ordering system), the clutch I have here is DR3Z-7B546-A and there is no updating part number. It is showing as backordered currently with a "Demand exceeds supply" comment.
So based on that information, there is not a newer number than this, and this is likely the part number your dealer has on order.
Seer
I just called them again, and they said the clutch has arrived, but waiting on the shifter now.
19COBRA93
Ford Racing
Clinton, Ut
Shifter arrived today too. The part # of the clutch they ordered had a "C" in the beginning.
That's the latest update for the '12 clutch. That's been out for sometime now, and is the clutch that's used for the TSB on the 07-09's. It's the same clutch I just installed in mine.
Seer
Dumb dealer lied to me.
BMR Tech
Traction Vendor
Tampa, FL
Maybe just a misunderstanding....
:roflmao:
BMR K-Member + JPC Engine Mounts + Modded CHE Brace + Custom Trans Mounts + Updated Clutch = One expensive way to ensure the gear is hit.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
:roflmao:
BMR K-Member + JPC Engine Mounts + Modded CHE Brace + Custom Trans Mounts + Updated Clutch = One expensive way to ensure BMR Kelley gets to go on a cruise this year.
Fixed.:clap:
Seer
:roflmao:
I have steeda engine mounts sitting here, it'd be nice if they work with the bmr k member.
How does the CHE Brace need to be modded to work with the bmr k member? Because I have a che brace sitting here, plus a mgw shifter.
zquez
Death Dealer
the sky
I ran with just the MGW for a bit, and while it didn't grind like yours it was hard as hell to get into gear and had to be forced. I put in lethal performance lowered motor mounts and it shifts pretty much like butter now. I have a feeling that once you get your motor mounts in you'll be very happy with them. The only thing I feel that could maybe make things better would some shims on the slave.
Seer
and the dealer scratched and dented my quarter panel. Lovely.
BAKnBLK2010
Harley Davidson FLHTCI
Sandy Hook Kentucky
Man that sucks. My car is at the dealer right now having the transmission pump replaced. I'm a nervous wreck thinking something just like this will happen to my car....
Seer
They called me and stated they will fix it on their dime.
BAKnBLK2010
Sandy Hook Kentucky
That is great that they are fixing it but you still will have a brand new car with paint work. It's a shame that stuff like this happens but it seems to happen pretty often when you have to leave a car at the dealer.
19COBRA93
Ford Racing
Clinton, Ut
Damn the luck. Back in '05 when my '03 Cobra had 2900 miles on it, I had it in the shop for some a/c work and the tech had a big metal shelf fall over on it. They paid to fix it, but it just wasn't the same.
Tight Lines
Illinois
Man, your post seems like you are calm. Not sure I could be but it is just a post. I hope it isn't to bad and it is fixed to your satisfaction.
Seer
What would I accomplish by shoving a foot in their ass? What else could they give me instead of fixing their mistake?
