Need help with suspension parts
Nikoloz
Hello, I own 2010 Mustang 4.0 v6 automatic. Im from Georgia(country) and i can not find any parts here from this list.
Rear lower control arm
Rear upper control arm
Rear centre bush
Front lower control arm bush
I'm searching for those parts on Rockauto and i dont know Partnumbers. some of them says that it goes 2005+, so im little bit lost. I dont want to buy the wrong parts cuz they are expencive and i dont want to pay twice. If someone can help how can i buy those parts without mistake, Please help me. Thank you and sorry for my English :)
Since your car is the same body style as the '11-'14 models, you can order suspension parts for an '11 V6.
Yes they do. They also have the same brake parts as the '11 V6 but the engine, drivetrain, fuel system, steering, and HVAC systems were carried over from the '09 V6.
Ordering parts for 2010 models (V6 and GT) can be tricky because it was a crossover year with parts mixed from '09 & '11.
Nikoloz
Its very helpful, Thank you! also if you can tell me rear control arm and front lower control arm bush, does they have difference between left and right? or are they simular?
Nikoloz
also if you know good site for make order, not all those parts ar available on rockauto.com
Its very helpful, Thank you! also if you can tell me rear control arm and front lower control arm bush, does they have difference between left and right? or are they similar?
The bushings are interchangeable from right to left.
also if you know good site for make order, not all those parts are available on rockauto.com
I've also ordered parts from CJ Pony Parts and Summit Racing.
Norm Peterson
corner barstool sitter
RIP - You will be missed
Better double-check part numbers for the upper control arm. There was a production change to a longer UCA that I think happened between the 2010 and 2011 model years. Either the later (longer) arm or the early shorter one will work, but the arm does need to be matched with the correct chassis-side UCA bracket.
Norm
Gabe
Whippled Coyote
Rear lower control arms are the same for all Mustangs 2005-2014.
BMR has a great set for only $89
Upper control arm changed for '11+
The upper center diff bushing (the one that's press-fit into the eyelet on top of the diff housing) can be purchased easily enough, I think I went with a Prothane unit for about $20 from Late Model Restoration or American Muscle, I forget where I got it.
Front lower control arms you can buy as complete units, would be a lot easier to swap and they include new lower ball joints.
Midlife Crises
Fairbanks, Alaska
With the 2010 it is helpful to know if the vehicle is early or late production. There was a front lower control arm “ball joint” change that took place that also affects the spindle.
