Plastic Bumper Paint Removal
Discussion in 'Keeping it Clean' started by MADGT, Jun 8, 2018.
  1. MADGT
    MADGT forum member
    1,160
    Aug 23, 2009
    Aldie, VA
    Team,
    I need to strip off the paint off a plastic bumper--what have you used that works well on plastic?
  2. Slick4.6
    Slick4.6 Junior Member
    49
    Sep 12, 2017
    Central NJ
    Aircraft paint stripper works very well, I can’t remeber though if there is one specifically for plastic or if it’s safe to use on plastic. Either way it literally melts the paint off.
  3. mrt2you
    mrt2you forum member
    55
    495
    9
    Jan 20, 2014
    new berlin
    i am a bodyman for over 30 years.
    SEM makes a plastic bumper stripper, https://www.google.com/url?sa=t&rct...ripper/77713&usg=AOvVaw3Hmzd49a_3pIo1J5QAnb-k.
    DO NOT USE stripper designed for metal. it can destroy the plastic.
    you could try stripper designed for fiberglass. i have never tried it so i can't tell you if it will or won't work.
    this stripper removes aftermarket paint, paint applied at a body shop. it will NOT remove a OEM finish. the best way to remove OEM paint is with sandpaper.
  4. MADGT
    MADGT forum member
    1,160
    Aug 23, 2009
    Aldie, VA
    Thanks folks - i have sanded the bumper down instead of stripping down the paint. Hope to paint it next week.
