Johnf78
My modified grille lowered my intake temps. While driving I am seeing 2 degrees below ambient temp.
Sent from my iPhone 5S
Not sure if I missed it but what did you do to modify the grille?
That was the deal we made one it!
Plan is to see this thing at 1,000+rwhp on many occasions. I am the blue collar tester of the block as all the others have been at these high $$$ builds by shops so far.
Ordering pistons next week(11:1 comp Diamond with dd coating and .200" wall tool steel pins)
Subbed. I'd rather buy this that have to send my block out to get it sleeved.
My understanding is that block has stock block sleeves. Just has smaller coolant passages on top.
subd should be a good build what are you doing for fuel or did i miss that?
Dont understand what your are getting at. Are the sleeves different? Because that was what my post was about.Can't see the forest for the trees? Take a good look at that deck and at a stock one. there's a whole lot different there.
Every water passage is different, even on the ends and between cylinders. I'd say all indications are there is a whole lot more aluminum in there.
Why only 11:1?
Thanks.
I was hoping you would of went, 12 or 13:1.
SStang.
