RunnerInTheNight
So again my car overheated, last month, and I played with it and then lost my job due to a seasonal position and ran out of money.
Anyway... here is what I've replaced so far and the fans aren't spinning after running over ten minutes and you can feel the heat pour off the motor and the coolant starts to boil
Fan assembly
ECT (took me a month to figure out the clip thanks to an amazing neighbor)
Tested/Checked
Thermostat is solid
Relays are both good in the under hood fuse box
The cooling fan small fuse (green 40) under hood fuse box is solid
Fluid level was good but now a little low from the ECT replacement
All connections connected
I did move some grounds around but I re grounded right into the chassis and have done this before without a problem.
Any ideas? Help?
Fan assembly
Tested/Checked
Thermostat is solid
Any ideas? Help?
