Hey everyone. So I'm "trying" to install koni adjustable yellows with steeda springs and upper strut mounts. I read a bunch of threads that said instead of a spring compressor tool just put a jack under the a arm, undo the bolts above and gently lower it down. I did that and it worked perfectly.
I put the new koni strut with the steeda mount sitting on top back into position, put in the two bottom bolts and started jacking it up. I got the steeda emblem aligned correctly, the strut mount bolts to come up through the holes and I finger tightened them down. Now the problem. The top of the strut with the threading will not come through the top of the hole. It comes up till the top of it is flush with the top of the strut mount and will not go any farther. It actually started to lift the car up. I'm not sure what the problem is. When I had the strut and steeda mount out of the car I was able to quickly push down on the mount and see the strut pop up through the hole enough to get the nut on, but obviously I wasn't able to hold it in that position to get the nut on. I don't get why jacking it up wont push the strut through.
Thanks.
Thanks.
