Beerhunter
Hello all, I had searched this before but for whatever reason I cannot find the tread again.
Basically, I am trying to detirmine if my fuel pump is toast. I don't hear whirr for 3 seconds when I turn the key. I'm thinking that all I have to do is put a multimeter on the connections at the fuel pump. If it reads ~12 volts for 3 seconds then the fuel pump is shot.
My question is this... if I don't show any voltage then what else can it be assuming that the relay and fuses are fine? Is there anything else that would prevent the fuel pump from starting up?
