J.Kidd
Not any more. All of the currently published Ford documentation on the MT-82 (as of September this year) calls for Motorcraft Dual Clutch Transmission Fluid. It's the only fluid listed for the MT-82 in the Owner's Manual and in Ford's Shop Manual. It's the fluid that Ford installs at the factory.
There was a time, fading fast in the haze of history, when Ford put Motorcraft Full Synthetic Manual Transmission Fluid 75w-90 in the MT-82. But those days are past and today, if a Ford dealer services or repairs one of those transmissions, it will be refilled with the Dual Clutch fluid.
So, what that means is that the transmission will probably work with any gear oil that's 75w-90 or thinner down to a viscosity comparable to an ATF. However, there's no evidence anywhere that ATF itself will work.
Yup - quoted directly from a TSB 11-3-18 addressing shift effort:
"SERVICE PROCEDURE
Replace the Motorcraft Full Synthetic Manual Transmission Fluid with 2.6L (2.7 qt) of Motorcraft Dual Clutch Transmission Fluid. Refer to Workshop Manual, Section 308-03A for the transmission fluid draining and filling procedure"
Anyone know where GM Synchromesh fits in with these synthetics? I still have 2 quarts on my shelf. Figured I'd use them in my '92's T-5 next time I change the tranny fluid.
As for the MT-82; I do notice a bit of increased effort when it is cold. I typically baby the car until she's warmed up anyway. I might just deal with the increased effort when cold knowing I have better protection when she's warmed up since it is only noticeable and not terribly intrusive.
