If you haven't tried increased spring rates, better dampers, etc., without lowering the car, then how do you really know that lowering the car really is good?
Proper testing means changing one, and only one, variable at a time. Unfortunately, it takes a better driver than me to actually detect anything more than major improvements, since improvement detection requires driving consistency on the order of a couple of tenths of a second per lap on the track.
That's why, while I'm annoyed that I'm "forced" to go with this solution for now, I'm not too bent out of shape about it. Certainly, it is essentially forcing me to change one variable at a time!
Without going to the megabuck coil overs, who makes stock ride height springs...that are stiffer than oem ? And if you do lower it, it has to be stiffer, so it doesn't bottom out. I couldn't find any stock ride height, but stiffer springs back in the spring + summer of 2011. But I didn't look as hard as I should. After a month of on + off looking, I gave up.
Dunno how much the lower CG from a 1.125" to 1.25" drop really makes. Everybody that does it, also uses stiffer lowering springs, so its not an apples to apples comparison. Stiffer stock ride height coils and better dampers vs same but lower coils would be a real fair comparison.
My guess is, for DD use, the stiffer, stock ride height coils would suffice. Then tweak the sway bar rates + camber. I'm sure the car could be made to handle quite well. Lowering is fine up to a point..until clearance issues arise. My PA auto tranny pan is 2.1" deeper than oem. Its the lowest thing under there. Then toss in high flow catted H and 4" diam resonators just b4 the axle. The cats are ok, but the resonators are down a bit...the saving grace being the rake of the car means more clearance. It all works, but had to be carefully thought out.
If I ever had a flat in the rear, my BMR lca relocate brackets would bottom out. They are aprx 3.5" above the ground. A 285-40-18 has a 114mm sidewall. I'm tempted to do what skwerl did, and cut the un-used lower portion off... or use the WL version. WL version is the same as using the center hole on the BMR (both have a 3" drop)
