HEMI LOL
The Feast and The Famine
maybe a cracked or broken PCV valve. a lot of things actually. a little bit is nothing to worry about, but if its really frothy then id start to see why the crank case is getting pressure.
i wouldnt worry about it.its only frothy around the oil cap area. there was a few very tiny bubbles on the dipstick...
and while a steel crank and rods are a good idea when you want to spin the rpm on up there, like fdjizm said it will be your stock valvetrain that will be the limiting factor on where you need to shift.
besides, you need to verify where your cars makes peak power. if 6500 is a good rpm (which sounds like it is), then 7k is just beating up your valvetrain and motor and not really accomplishing anything.
based on that chart i wouldnt shift any higher than 6500.i made a thread on my dyno can you go look and tell me if you think i am making power up high? it looked like my rwhp was still climbing when we stopped...
here it is..
http://www.s197forum.com/forum/showthread.php?t=44229
but 120+mph is a damn good trap speed...you started at 116 and went all the way up to 120 thats good.
but remember, blower cars are sensitive to weather. you had a nice cool evening...go back when its warmer and things can change.
idk if your mph would go up that much higher...id say the mph youre at is about as good as youre gonna get. but yes, with a good 60ft and some better shifting your car should go 11s easy.if i had a short shifter, and get my 60 ft down to 1.8, i could probably run 12.0 @ 124
will nitto nt555's allow for a 1.8?
thanks man! hey based on my 120 mph trap, if i get my launch a little better, and a short shifter, is 12.2 ish possible?
Your trap speed won't go up that high and will likely hover in the 118-120 range (depending on weather). With a proper drag radial or slick, there's no reason you can't run 1.7's to the sixty foot. I have much less power than you, I have a lazy automatic, launch at 4800 rpm's, and I run high 1.6's and low 1.7's. I expect you could easily match that with the right tires.
Your car should really be able to run 11.30's based on your 120 trap speed. It's all in the launch now.
thats good to know, so i have enough to take a stock zo6, all i have to do is perfect my launch.
i was thinking about slipping the clutch to prevent spin, also dont forget i also have a stock 93k mile clutch lol
also is it possible the offset on my rims are hurting my time?
