Hi,
New-ish member here, with a '13 Brembo GT starting off all stock. Car is my daily driver, commuting 50 mi. a day round trip over mixed surfaces, so I've been hesitant to move away from stock, especially on ride height. And for the first 35k mi, I just enjoyed owning a V8 pony car (and the Mustang I've always wanted).
That said, I have a couple concerns now that the car isn't brand new anymore:
1.) Wheel hop. I can't launch this car hard, at all; anything above 3k rpm and the axle starts tramping and doesn't stop until I lift. It's been like this since I bought it (on the stock summer P Zero tires, and a replacement set of the same). I suspect the tires have something to do with this, but as I'm on a new set in the rear (long story) I'm going to have to deal with that factor as best I can till they're worn out.
Are LCAs likely to help reduce the axle tramp? I've read some past threads (and Vorshlag's epic 2011 build) and the consensus is... well, there isn't one. Whiteline has a good rep with many, but they're basically a poly/poly design and others advocate for more articulation. Honestly, I'm afraid of rod-ends and sphericals on a DD. But, I'm intrigued by the del-sphere/roto-joint design on the axle side that some offer (UMI; others?).
2.) Damping. The car has poor body control, which is no surprise to anyone who's driven one. I know opinion here is 'divided' between Koni & Bilstein shocks/struts, but regardless of brand I assume there's agreement that replacing the stock dampers is worthwhile, even when staying on OE (non-lowering) springs? Is there any opinion on some of the other strut/shock combos out there like Steeda Pro Action and Eibach Pro Dampers? Not sure I want to go with adjustables, but if I did the only options in my budget would be Koni Sports or FRPP (D-Specs, from what I gather).
Again, the goal is just to fix a couple foibles with the car as my fun daily driver. I may eventually get to a track day/HPDE or the occasional autoX, but I'm not building towards that end, or concerned about class rules (famous last words...).
